Jul-01-2013 10:28 AM
Jul-26-2013 01:19 AM
LeBout wrote:
Oh sure! Throw the ol' "My pickup is newer than your pickup" thing in my face! 🙂
Kidding, of course. I'm sure you're right about all that. I guess the OP didn't specify whether he could afford a new pickup or was going to go with used. (How DO you afford those new ones, anyway???) 😉
Jul-25-2013 05:27 PM
Jul-25-2013 05:21 PM
ToneDog wrote:The price difference is usually so small....That it makes little sense not to get the 1 ton (SRW)
At what point should one consider a 1 ton vs 3/4 if in the market for a new truck?
Jul-25-2013 04:54 PM
Mike Up wrote:
While the old 5.4L 3V and 4 speed transmission could get it done, it was weak while doing it. If your judging solely on pulling power, the new drivetrains leave yours way behind.
Jul-25-2013 03:40 PM
Jul-25-2013 01:03 PM
Mike Up wrote:myredracer wrote:
I fail to understand why people think that the payload capacity published by a manufacturer or what is shown on the door jamb sticker is what it actually is and that they can load their truck up to that figure and tow just fine.
All I know is that our 3/4 ton truck is about 1000 lbs less payload capacity than what the door jamb sticker says.
The tread act sticker is mandated by the government and is more accurate than the +/- 50# accuracy of a cat scale.
Jul-25-2013 12:34 PM
It is so easy to find a scale and get a weight so why not try it even if just out of curiosity? You could find yourself getting a big surprise. It's better to be fully informed rather than flying blind. But then there's those that don't care anyway if they are grossly overloaded and know it.
All I know is that our 3/4 ton truck is about 1000 lbs less payload capacity than what the door jamb sticker says. Sure glad we weighed it. Even though we have a 29' lightweight TT, it's still possible to overload it without too much difficulty.
Jul-25-2013 12:07 PM
Jul-25-2013 11:43 AM
bparks1987 wrote:
Hey all. I'm looking to purchase my first trailer. My question is this. What is the smallest truck size you all would go for towing purposes. I currently have a 2010 2WD ST long bed. V8 4.7L engine. Not very big for towing a trailer. I know I need to buy something bigger, I just don't know how big. Will a 5.3L be big enough. Will a hemi be ok? Or do I need to upgrade to a 2500 to be safe. Any info would be great. Thanks!
Jul-25-2013 11:18 AM
LeBout wrote:
I have a 5.4L V8 (F-150) for a TV and a 25 foot TT with a dry weight of around 5300 lbs and loaded weight (guessing here) maybe 6000 to 6500 pounds depending. After pulling that trailer half-way across the U.S. and back I can tell you I would NOT WISH to pull any more weight than what I have! My engine is bigger than yours and your TT would be heavier than mine!
Conclusion: Either get a 3/4 ton for a TV or start looking at smaller TTs with less towing weight.
Jul-25-2013 10:29 AM
APT wrote:
The SAE spec does not particularly help with RV towing anyway where acceleration is not the limiting factor to determine tow rating. Payload and receiver limits are likely exceeded when towing an RV well under half ton tow ratings.
Jul-25-2013 07:28 AM
bparks1987 wrote:
Thanks for the info everyone! It all helps. I'm looking at a Flagstaff V-Lite 26 WRB, or something similar (if anyone knows any thing similar let me know!). It says it's gross weight is 7,100, which is just under the 7,500 it says my truck can hold. Based on everyone's info, I'm going to have to do a little more research just to make sure the numbers are right. Thanks again all!
Jul-25-2013 06:06 AM
Jul-25-2013 05:42 AM
