truck is sitting lower than it used to with TT hitched up
plasticmaster
My 2000 Silverado squats down much lower in the rear than it used to with my travel trailer hitched to it. When I first noticed it, I adjusted my load bars one chain link and that seemed to help. But now, it is squatting even lower than before. It is the same travel trailer loaded basically the same way so the weight has not increased. What's going on here?
9 REPLIES 9
Drew_K
plasticmaster wrote:
Do the shocks have anything to do with how much the truck sags when I hitch up the camper? Would replacing the shocks help?
Not at all. The springs control how much the truck moves up and down; the shocks control how quickly that movement occurs. Replacing the shocks won't help the issue you're asking about.
2013 F250 CC 4x4 Diesel
2014 Open Range Roamer Travel Trailer RT316RLS
plasticmaster
ib516
x2 on the broken leaf in the spring pack or bent receiver.
Prev: 2010 Cougar 322QBS (junk)
02 Dodge 2500 4x4 5.9L CTD 3.55
07 Dodge 3500 4x4 SRW Mega 5.9L CTD 3.73
14 Ram 2500 4x4 Crew 6.4L Hemi 4.10
06 Chevy 1500 4x4 E-Cab 3.73 5.3L
07 Dodge 1500 5.7L Hemi 3.55 / 2010 Jayco 17z
All above are sold, no longer own an RV
Bob_Olallawa
Check the truck receiver, I bet the tube has sprung and the receiver is twisted up instead of straight out causing the spring bar chains to carry less weight...
Welcome to my home, that door you just broke down was there for your protection not mine.
TXiceman
Make sure you are not carry a bunch of water in the tanks.
Ken
Amateur Radio Operator.
2023 Cougar 22MLS, toted with a 2022, F150, 3.5L EcoBoost, Crewcab, Max Tow, FORMER Full Time RVer. Travel with a standard schnauzer and a Timneh African Gray parrot
Ron3rd
Is this something that is easy to repair or replace?
Simple job for a spring shop.
Equilizer Hitch
Honda EU2000
plasticmaster
vortec22
Try to see if any of the leaves in the spring pack have fractured. Had a buddy whose truck did that and had the same symptoms. Different brand, but that doesn't matter.
2015 Chevy Silverado 3500 CC LTZ Z71 Duramax/Allison 4x4
Ron3rd
Maybe your leaf springs have sagged?
Equilizer Hitch
Honda EU2000
