Assuming your truck is wired right, It sounds like there are some crossed wires. You can look at wiring diagrams, but 7 pin connectors usually make it easy to swap wires with wires secured by screws. With some trial an error, you can straighten the wires out even if your truck has a few things reversed. There are plenty of diagrams available for 7 pin connectors, or if you buy a new one, many come with wiring diagrams.
'10 Ford F-450, 6.4, 4.30, 4x4, 14,500 GVWR, '06 Host Rainer 950 DS, Torklift Talon tiedowns, Glow Steps, and Fastguns. Bilstein 4600s, Firestone Bags, Toyo M655 Gs, Curt front hitch, Energy Suspension bump stops.
NRA Life Member, CCA Life Member
