โMar-18-2018 11:50 AM
โMar-18-2018 09:45 PM
jonwegs wrote:
Lance's wiring harness has the positive and negative wires as 8 gauge, and Lance specifically said don't use charge cables smaller than 8 gauge.
โMar-18-2018 09:23 PM
โMar-18-2018 07:57 PM
Kayteg1 wrote:
BUT WAIT !
There is more ๐
Running bigger than factory #10 wire to camper would make sense when you have 6-battery bank, but rule of thumb says you should not charge the batteries with current bigger than 10% of their capacity.
So 100 amp-hr battery should not be flooded with more than 10 amps.
Ford is the only brand that is having trailer 30 amp charging wire operated by ignition, so check if yours might already have it.
Bigger wire with bigger connectors might make sense when you use 12V for fridge, but sounds that you might already have all you need?
โMar-18-2018 06:12 PM
jonwegs wrote:
Thank you everyone for the info. I have some reading to do now. As for your question Brad, my fridge has the 12v option but I plan to mainly run it off propane.
Based on the info I have thus far, it sounds like I need to buy 20+ feet of 8 gauge or bigger wire, possibly a constant duty solenoid or a battery isolator (still need to read a bunch on those to understand which I need). I have seen some folks take the positive and negative wires out of the Lance harness and wire those up to the battery, while just using my existing 7 pin in the truck bed for the running lights. This makes sense to me, does anyone see any issues with doing that?
โMar-18-2018 05:50 PM
โMar-18-2018 05:35 PM
trail-explorer wrote:jonwegs wrote:
While others say just wire it directly to the windshield wiper motor.
That's the most bizarreway of wiring in a charge circuit that I've ever heard.
To the wiper motor is NOT the right way to do it.
โMar-18-2018 05:30 PM
d3500ram wrote:Camper_Jeff_&_Kelli wrote:
Here is how I did my 4 gauge wire and solenoid installation. There are several other examples in the Truck Camper University sticky section.
4 Gauge Charge Wire
Jeff- I think that is the single longest thread I have ever scrolled!
Nice job and documentation!
โMar-18-2018 05:19 PM
โMar-18-2018 03:14 PM
4 Gauge Charge Wire
โMar-18-2018 03:13 PM
โMar-18-2018 03:07 PM
โMar-18-2018 02:59 PM
AnEv942 wrote:
Search constant duty solenoid will bring up a few old threads, also a couple in the TCU sticky. Simplest and effective is using constant duty solenoid-triggered by ign hot.
โMar-18-2018 02:51 PM
jonwegs wrote:
I tried this and the running lights work, but I now know the smaller gauge hot wire and ground won't charge the camper battery.
โMar-18-2018 02:36 PM
