May-15-2021 09:14 AM
May-15-2021 10:09 PM
Hemi Joel wrote:
I drink my RV water, so I i need it to be safe. It is so convenient just to fill a glass from the faucet, and free. I usually sanitize with bleach every 24 months or so.
May-15-2021 10:08 PM
May-15-2021 03:22 PM
May-15-2021 01:16 PM
JimK-NY wrote:
First, vinegar does kill salmonella, E coli and some other bacteria but overall it is not a great disinfectant and certainly no where near as effective as chlorine bleach. Why not just use bleach since it is much more effective.
Hot water tanks can develop quite a bit of scale. Pumping some vinegar into the tank and letting it soak should help, but I would certainly not pump that residue into my fresh water tank or even through the hot water pipes and faucets. Pull the plug and let it drain out of the tank instead.
I have never had an issue removing the bleach from the water system. I drain the tank, add a partial tank of fresh water, drain again, and then fill up.
There are plenty of campers who do not sanitize their fresh water tanks. Most of them do not drink water from the tank. Even so I recommend reconsidering. Sanitizing helps to remove the pink slime (pseudomonas bacteria) that grows in water tanks. It is relatively harmless for most people but can start to clog faucets. I am also concerned about Legionela. I had a friend who was very sick from Legionnaires and that bacteria is often found in RV hot water systems and the shower head. It takes little cost, time or effort to sanitize so I cannot understand why anyone would skip this.
May-15-2021 01:10 PM
2oldman wrote:Kayteg1 wrote:18 years for me.
30+ years of RVing and I never sanitized fresh water tank.
May-15-2021 12:58 PM
May-15-2021 12:27 PM
Ed_Gee wrote:
Just for the record, the recommended sanitary standard for sanitizing the RV fresh water system is 1/4 cup bleach for every 15 gallons of water. Looks like your formula is a bit deficient in bleach.....
May-15-2021 11:42 AM
Acampingwewillgo wrote:Just showers, toilet and dishwashing for me.
I think I've sanitized once 20 years ago....easy not to worry when "we" don't use tank water for drinking.
May-15-2021 11:22 AM
May-15-2021 11:08 AM
May-15-2021 10:54 AM
May-15-2021 10:45 AM
May-15-2021 09:25 AM
