TV tire pressure?
cpap
Just curious if anyone increases tire pressure when towing. I asked the Dodge dealership and was told no change in tire pressure for towing for my 2014 Ram 1500.
2014 Ram 1500 Ecodiesel Laramie
2013 Jayco Jayflight Swift 264BH
2014 Jayco White Hawk 27RBOK...picking it up 7 Nov
8 REPLIES 8
Beaker
Which is what my tire manufacturer recommended. But.......
2008 Silverado 2500HD Duramax
2010 Cruiser 26RK
ktosv
Theoretically, the tire pressure listed on your door jamb is the pressure that is required to meet the vehicles GVWR. As long as you aren't overweight, you technically don't need to do anything with your tires.
However, by increasing the pressure some may actually find that the vehicle rides/drives/handles better when loaded.
My door jamb says 55 front, 80 rear. When not towing or hauling I run 50-55 in the front and 62-65 in the rear. When towing I increase the rear to 80.
Kevin and my...
Wife and six kids
2017 Suburban (5.3L/6A/3.08)
6x12 Enclosed Utility
Sold...2011 Express 3500 (6.0L/6A/3.42)
Sold...2010 Passport Ultra Lite 2910
mikeh449
it depends on the type of tires you have p rated on 1500 35 to 40 psi lt tires e rated or higher 50 to 80 depending on valve stem rubber max 50 steel up to 80
wandering1
PSI should be whats on the sidewall.
HR
BB_TX
I sometimes let some air out of the rear tires if I will not be towing the 5er any time soon. But most of the time I just leave the 80 psi there.
65 in the front never changes.
azdryheat
I don't change the air pressure from what the door sticker says (70 front, 65 rear) and tire wear and ride is great whether towing or not. My last truck I towed at max (80 psi) and the tires didn't wear properly; learned my lesson.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
ScottG
It doesn't surprise me that a dealership has no idea how to air up truck tires.
Check your door sticker first.
You probably can run a lower pressure than max for everyday use. But when you load the truck up, you need more air in the tires so they can safely haul the weight.
K_Charles
The tires on my excursion have X pounds at 80 psi. The door sticker says way less psi. If I leave 80 psi in the tires when not towing it rides like a truck. If I unhook for more then a couple weeks I let some air out.
