Using the slides while retracted
drumming102
We have a 2015 passport 2920BH with a jacknife and U dinette on a slide. Are you able to sit on the sofa or use the dinette while retracted? I have shyed away from it because it feels like the slide flexes when you step on it while its retracted and it feels like you might break something if you put your full weight on it.
2008 Chevy Silverado 1500
2015 Keystone Passport 2920BH
13 REPLIES 13
tatest
It depends on the slideout design and structure. I am able to sit on the sofa in slideout of my motorhome when it is retracted. The sofa came equipped with two seatbelts so it could be used when moving.
But this is a C motorhome, not a lightweight TT. If yours feels like it flexes when you step into it, it is probably not built heavily enough to handle the weight, rather is fully supported only when pushed out to lock into the opening.
Tom Test
Itasca Spirit 29B
colliehauler
Old-Biscuit wrote:
Does your slide tilt up when retracted vs laying completely flat on floor?
Tilts up....no support under slide floor so NO don't step on it, walk on it, get inside slide etc when retracted.
Floor and consequently the whole slide is not supported unless extended.Then it becomes a fully supported unit
If slide moves in/out flat on top of trailer floor then it is self supporting when in or out like a bedroom slide with bed
X-2
Rangerman40
I won't personally use mine but I put my 35lb daughter on ours all the time to sleep when we stop at a rest stop on the way to a destination.
harley4275
I also use 3 pieces of 3'4 " ply . one on each end and one in the middle under the dinette seat back. Helps stop flexing as we travel also .
2013 Sunset Trail 25RB TT
2015 Silverado 2500HD 4x4 6.0 l gasser.
Equilizer 4 pt
From Belle River, Ontario
2003 Mountain Star 890sbrx Truck Camper
Old-Biscuit
Dbl post....
goducks10
Just stick a piece of plywood under the leading edge of the slide. Our Northwood has a flexing slide floor when retracted. NW say its fine to step on. I don't like the way it flexes so I just slide a 6"x24"x5/8" piece of plywood under the leading edge. Pick the size of ply that works.
Old-Biscuit
dodge guy wrote:
I wouldn't use any slide in the in position. They just weren't designed to be used that way.
Unless they are a above floor design vs flush with floor design....
Flush with floor design drop down 'flush' when extracted and ride up over floor when retracted. Those are NOT designed to be used retracted.
Above floor design just go in/out above main floor. You have to step up onto them regardless of position.
Beds on slides use that design and many MH slides are like that.
They are self supporting in or out.
dodge_guy
Wife Kim
Son Brandon 17yrs
Daughter Marissa 16yrs
Dog Bailey
A bad day camping is
dahkota
The manual on our Keystone Sprinter said not to. You might check yours.
2015 Jeep Willys Wrangler
2014 Fleetwood Bounder 33C
States camped: all but Hawaii
more than 1700 days on the road
Anmacc2
I have a passport 23rb. We have one slide with the sofa in it. We use it retracted all the time. Ours feels solid though. Can you check with the manufacturer? We're lucky because the service tech at our dealership is a friend and gives me straight truthful answers.
Me & Her since 1977
TV 2014 Ford E350 Superduty
TT 2015 keystone Passport Elite 23RB
Boat 20' TriumphDC
bid_time
Nomad II
Nomad II
drumming102 wrote:
....it feels like the slide flexes when you step on it while its retracted and it feels like you might break something if you put your full weight on it.
You answered your own question.
drumming102
Ok, i believe the bottom is elevated when in by an inch or 2
Old-Biscuit
