Using truck camper when not attached to truck
jwal12291
I recently bought a 1985 sun lite truck camper. I want to be able to take it out of my truck when i get to where I am going and use it when its out of the truck.This particular camper only has three jacks two on one side in the corners and 1 on the other side dead in the middle. I more asking if anyone has any ideas on what i could build or do to set it down on that would make it sturdy enough to stay in.
16 REPLIES 16
jimh406
I've used aluminum camper Jack's with 2x6s just to have a bit less movement. https://www.etrailer.com/Camper-Jack/Ultra-Fab-Products/UF48-979003.html
Here's another example thread using plywood. http://www.rv.net/forum/index.cfm/fuseaction/thread/tid/27024272.cfm
jaycocreek
Aluminum stack jacks with a 2X6 or 2X4 across the front and back jacks...They are rated for a lot of weight..
Saw a guy unload his 10ft camper to haul out his elk to a cooler and did just that, while the wife/dog and kids ran in and out of the camper while he was gone.Looked very sturdy as well and he carried it all in his TC without a trailer.
Impressive
Lance 9.6
400 watts solar mounted/200 watts portable
500ah Lifep04
