V10 Higher Octane?
RAllison
I have a 2002 F350 V10 with 235000 miles on it, and I have always tried to run the higher octane gas. Just wondering if that was a waste of money? Thanks Rich
21 REPLIES 21
ktmrfs
smkettner wrote:
If it calls for 87 that is what it needs in all conditions.
Higher elevations you can probably even go lower, I don't.
above about 3500ft you'll find that pump octanes are 85, 87, 89 for regular, mid and premium instead of 87, 89, 91 needs go down even more above that altitude.
Unless the manual calls for something other than 87 octane your not going to gain anything. engine ecu isn't going to give more advance,
2011 Keystone Outback 295RE
time2roll
msgtord
TUCQUALA wrote:
I don't consider it a waste, esp towing in the mountains and hot weather. Higher octane will help prevent detonation under those conditions. Then the computer won't back the timing off as much or any. Most of the time, I don't use premium, but will if towing heavy in hot weather.
Same here.
1995 Fleetwood Mallard 22B.
2014 Ford F250 Crew Cab. 6.2, 4x4.
TUCQUALA
'16 Outdoors Timber Ridge 280RKS
Reese 1700# Trunnion w/ DualCam HP
'03 EXCURSION XLT V10 4.30 Axles
azdryheat
If it doesn't ping on regular then there's no need for higher octane.
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
samsontdog
I have a 2003 F250 with the V10 and it runs great without the higher octane
samsontdog:o:W
jerem0621
Yes it is a waste. No need to run higher octane fuel that it was designed for. Ran regular in my V10, 5.4, and my current 4.6.
Thanks!
Jeremiah
TV-2022 Silverado 2WD
TT - Zinger 270BH
Itโ€™s Kind of Fun to do the Impossible
~Walt Disney~
