Valve Stems on a Dually
freddmc
I have a 2005 Ram Dually and am getting new tires so this might be a good time to address accessibility of the valve stems on a dually. What options are there so it is easy to check tire pressures and add air to the tires?
Thanks
Fred.
9 REPLIES 9
katfish
harley-dave wrote:
I like and use the Borg valve stems on my duals. Look HERE. Stopped my air leaks and made it easy to air up. My local tire shop carries them, your might. If not order a pair.
Dave
X2. Best thing I could get for my truck.... Got them straight from Borg....
"Every day is a adventure and every trip is a voyage of Discovery"
Steve & Cathy
U.S. Coast Guard (retired)
2012 KZ StoneRidge 36ul
2004 Dodge 3500 (Diesel DRW)
Advanced Air Rider hitch
fj12ryder
kennethwooster wrote:
Found out I couldn't get my hand in to even get the caps off. A mechanic friend did some checking and was told to use the extenders, and are braided, and have a bracket that bolted to the outside wheel. I've driven about 900 miles and so far no problem. 450 of those miles was towing. I think this will work but not enough miles yet.
Yes, I had a set of those. They lasted about a year or so before they started leaking. Hope you have better luck with yours. 🙂
Howard and Peggy
"Don't Panic"
C_Schomer
I used longer stems in mine and they work good with the right inflator head... straight on the end and angled on the back. I think I used 2" stems but a little longer, maybe 2 1/2" would be better just because it would be easier to see them and get the inflator on, on the outside wheel. Check with your tire shop to see if they have them. I had to find my own cuz the tire shop I used had the most worthless pack of idiots I ever saw but that was unbeknownst to me, at the time. Craig
PenMan
IAMICHABOD wrote:
The Tire Man has the best and the original ones on the market.
TIRE MAN
I used Tire Man also. Don't use the flexible extensions (as others sometimes recommend) as they leak and sometimes break. Also, if you ever want to add a tire pressure monitoring system, you will need the steel valve stems like Tire Man. I have no affiliation with Tire Man other than being a customer.
Chris and Jane
2013 Open Range Journeyer JT337RLS
2006 Dodge Ram 3500, 4x4, Crew Cab, DRW, 5.9 turbo diesel
1996 Harley Davidson Electraglide
Hank85713
Camp world sell extenders 2, 3 4 inches long. They also have the angled ones 45 and 90 Deg. I use the longer ones for my inners. I did use locktite to keep them from coming loose and in 5000 miles no issues.
I have alcoa alum wheels and they have small holes and barely big enough to get a chuck thru let on get to the stems themselves. I also bought a straight head chuck for my home compressor and an digital tire gauge as the offsets just wont work right. BTW I got the gauge at CW for around $30, pepboys has them for $25!
kennethwooster
kenneth wooster- retired farmer. Biblical History Teacher in public HS, and substitute teacher.
wife Diana-adult probation officer, now retired.
31KSLS Full Body paint Cameo
Ford F350 2014 DRW 4X4 King Ranch.
20K B&W Puck mount hitch
fj12ryder
Using the proper angled head makes it a pretty easy job, even without the extensions. I have regular valve stems on my Dodge and it isn't too much of a problem.
I've had extensions and all three sets I had failed sooner or later. The longer/bent valve stems look to be a good solution.
Howard and Peggy
"Don't Panic"
harley-dave
Dave
2005 Winnebago-Itasca Sundancer 31C
2010 Harley-Davidson Soft tail Deluxe
2014 Harley-Davidson Street Glide Special
1999 Chevrolet Tracker 4X4
SKP # 121272
IAMICHABOD
TIRE MAN
Former El Monte RV Rental
Retired Teamster Local 692
Buying A Rental Class C
