Was I miss informed
tkhollywood
Need to replace one of the tail lights due to daughters breaking license plate bracket of tail light. So I ask the dealer for the sealant for the tail light, and he tells me to use silicone caulk, is this right? It's an aluminum sided trailer, and I thought I read numerous times not to use silicone.
2014 F150 cc
2014 Whitehawk 33bhbs
8 REPLIES 8
tkhollywood
Thank you for all the input, I think I will stick with the Butyl tape and Proflex. Also pick up a large roll of the Eterna bond tape for roof. Is it best to remove all lap sealant and replace with a fresh layer before applying the Eterna bond tape or just clean roof, and then apply tape?
2014 F150 cc
mwebber78
Butyl tape under the fixture, Geocel Proflex around the edge. Silicone is great for the shower and your sink but that's about it.
2013 Jayco Eagle 334RBTS
Disclaimer for the daft: Don't confuse my opinion with facts.
skipnchar
All of the external fixtures I've seen are sealed with butyl tape (sometimes called putty tape)
2011 F-150 HD Ecoboost 3.5 V6. 2550 payload, 17,100 GCVWR -
2004 F-150 HD (Traded after 80,000 towing miles)
2007 Rockwood 8314SS 34' travel trailer
US Govt survey shows three out of four people make up 75% of the total population
ScottG
Silicone is not for rubber roofs (maybe thats where you remember it from) but is "OK" for aluminum. But as others have said there are products that hold up better to the elements.
spike99
WoodGlue wrote:
GeoCel ProFlexRV makes an RV specific type of sealer and it's good stuff! WoodGlue
+1.
I love - click here - as well. Its expensive. But, well worth it.
WoodGlue
GeoCel ProFlex makes an RV specific type of sealer and it's good stuff!
WoodGlue
2002 Land Rover Discovery II
2014 Lance 1685 - Loaded - 4 Seasons - Solar - 2 AGM's
When Hell Freezes Over - I'll Camp There Too!
Lance Travel Trailer Info - Lance 1685 Travel Trailer - Lance 1575 Trailer
wkswenson
You could use silicon but my experience is that it will look nasty in short order, and while it is flexible, it tends to loose it's adhesion too quick.
I would use Geocel Pro Flex products or something like that instead.
Walter & Donna Swenson
2013 Cedar Creek 38FL - Front Living, Trail Air
2011 Dodge RAM 3500 6.7 CTD DRW CC LB
Our Website - "A Work in Progress"
Fish-a-Palooza
I think there are much better sealers like 3M 4000 UV. IMO Silicone deteriorates and mildews too quickly and I wouldn't use it.
Wayne & Karen
TT-2005 Komfort 27TSG
TV-2003 F250 Lariat Crew cab, 6.0L PS, FX4
