water heater connections
bluearc
Can someone describe this type of connection and how it comes apart.
thanks
19 REPLIES 19
bluearc
this is a pic of the fitting going into the tank
bluearc
I will try to post a pic
bluearc
It dosn't fit it is too small going into the gray line. I was wondering if a 1/2" copper flare fitting would work.
JoeChiOhki
JoeChiOhki wrote:
bluearc wrote:
Yes it is gray.
Okay, you have polybutelene pipe which is a different material than pex.
You'll need a sharkbite adapter to go from the older gray pipe to pex to tbe 1/2" mpt to connect to your water heater.
Specifically a 1/2" Polybutylene to Pex adapter. Its a push and done part, costs more than the clamp band variety, but it will successfully adapter from your old pipe to the modern stuff.
My Blog - The Journey of the Redneck Express
CB
Channel 17
Redneck Express
'1992 Dodge W-250 "Dually" Power Wagon - Club Cab Long Bed 4x4 V8 5.9L gashog w/4.10 Geared axles
'1974 KIT Kamper 1106 - 11' Slide-in
'2006 Heartland BigHorn 3400RL
Freep
AnEv942 wrote:
Suprising-though never looked
online shows it at HD/lowes if you have the sharkbite tools, ring also needed. Assuming line end
I love the sharkbite fittings and will opt for that first every time. Sure it's a little pricey but well worth it to me. I keep a little bit of pex, a cutter and a few extra fittings in the basement, just in case.
2014 Lance 992
2014 Ram 3500 DRW Turbo diesel
JoeChiOhki
bluearc wrote:
Yes it is gray.
You'll need a sharkbite adapter to go from the older gray pipe to pex to tbe 1/2" mpt to conne t to your water heater.
CB
Channel 17
Redneck Express
bluearc
Yes it is gray.
JoeChiOhki
bluearc wrote:
I bought the fitting at Lws however, The female threaded end screws in to the tank ok but the brass part has too much play and does not fit the tubing tight enough. Also tried Hmdept with out luck.
The original fitting going into the water pipe is plastic and a bit wider than the brass.
The water tubing is blue and snugged up with the a copper ring.
I have a few things to get ready on the camper for the winter in AZ. Maybe look for some gold there.
I would like to post a pic of my rig but getting a photo in is too much trouble.
Is your pipe gray in color by any chance?
CB
Channel 17
Redneck Express
bluearc
JoeChiOhki
AnEv942 wrote:
Similar to ours.
Ours and most use a swivel connection that threads onto water tank. Ive seen pictures of fittings without swivel that were threaded onto tank and then lines crimped on-
hopefully yours isn't one of those- a bit more involved.
I prefer those kind of Pex clamps, they're about 10,000 times easier to remove than the copper band type. A pair of end cutters and a good twist will usually break the clamp band, then its just a matter of prying it loose with some needle nose pliers and a flat head screw driver.
CB
Channel 17
Redneck Express
AnEv942
http://www.homedepot.com/p/1-2-in-Brass-PEX-Barb-x-1-2-in-Female-Swivel-90-Degree-Elbow-UC532LFA/202...
https://www.lowes.com/pd/SharkBite-1-2-in-dia-Brass-PEX-Adapter-Elbow-Crimp-Fitting/1000182985
https://www.amazon.com/SharkBite-UC532LFA-Swivel-Elbow-2-Inch/dp/B007AHJA1Q
push to connect brass
http://www.pexuniverse.com/1-2-x-1-2-fnpt-swivel-elbow-push-fitting
Flair-it also makes compression ells
https://www.amazon.com/gp/product/B000BQSUX2/ref=s9_acsd_hps_bw_c_x_2_w
01 Ford F250 4x4 DRW Diesel, 01 Elkhorn 9U
Our camper projects page
http://www.ourelkhorn.itgo.com
bluearc
I went to a few places like HD and Lws but could not find a matched a fitting, I need the swivel 90 going in the tank.
AnEv942
Similar to ours.
d3500ram
bluearc wrote:
Im having trouble posting pictures of the tank.
Just go to THIS SITE and drag n' drop the file (or browse to it) and then copy and paste the resulting string into your reply text wordage.
Sold the TC, previous owner of 2 NorthStar pop-ups & 2 Northstar Arrows...still have the truck:
2005 Dodge 3500 SRW, Qcab long bed, NV-6500, diesel, 4WD, Helwig, 9000XL,
Nitto 285/70/17 Terra Grapplers, Honda eu3000Is, custom overload spring perch spacers.
