Water issue
Abbydaddy72
While prepping my camper for a boondocking trip, I put water in the holding tank to test my pump. Water pressure was really low and water was spewing out of the city water connector. Any idea what causes this?
6 REPLIES 6
Bumpyroad
mbopp wrote:
You can try depressing and releasing the check ball in the city water connector also.
the first thing to try.
bumpy
mbopp
enblethen wrote:
Check valve is stuck either by debris or spring is broken.
You could use a hose plug to stop it until you can replace the check valve.
May be the cheapest and quickest fix.
2019 F250 XLT Supercab
Just DW & me......
Abbydaddy72
Wow! thanks for the quick replies!
I will look at the check valve and roll from there.
enblethen
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
calamus
Plug the city water connection and check it. How long are you running it you may need to let it fill the water heater before you get more pressure.
2015 3500HD Chevy Dually Duramax, 2008 Sundance 2014 22'SSX bennington pontoon
HappyKayakers
Check valve on the city water connection? Anything else, we'll need more details on your camper.
Joe, Mary and Dakota, the wacko cat
Fulltiming since 2006
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2017 Open Range 3X388RKS, side porch
