Mar-30-2017 02:05 PM
Apr-04-2017 05:57 PM
Apr-04-2017 05:54 PM
Apr-04-2017 12:04 PM
Apr-03-2017 03:36 PM
Chaz59 wrote:
Well I broke down after all your comments and bought the adjustable Volterra water regulator gauge and guess what I set it at 40 and I still have leaks . I unscrewed the fitting off the back of the toilet they're supposed to be a washer in that fitting I was told there is no washer so I inserted the washer a dealer gave me doesn't appear to be leaking at this time . Now I have one more leak just like it if I can get to it that's the problem . Thanks for all your comments
Apr-03-2017 03:10 PM
Apr-01-2017 10:03 AM
Apr-01-2017 04:20 AM
Mar-31-2017 08:45 PM
Mar-31-2017 02:32 PM
Mar-31-2017 08:05 AM
Sprink-Fitter wrote:Lantley wrote:Sprink-Fitter wrote:Oasisbob wrote:
One may cancel the other. You need to fix the leaks. This is the only real solution my friend. Stop spending your money to compensate for poor quality.
Water only flows one way, how might one cancel the other?
If initial pressure is 80 and 1st regulator cuts pressure to 40 PSI what is the 2nd going to do? Cut it to 20 psi? Nothing at all?
Why have 2?
The better adjustable regulators have a gauge. They are about $50.00 not $75.00. The gauge is the key. It will tell you what the pressure is vs. wondering.
2 of the el cheapo's will not tell give you a display of the actual pressure.
Why do you quote me? I'm not arguing that fact
Mar-31-2017 05:52 AM
Mar-31-2017 05:19 AM
Why have 2?
Mar-31-2017 04:32 AM
Mar-31-2017 03:34 AM
