Water Pump Was Left On
joeshmoe
Apparently, my wife bumped the switch and never noticed it. She was cleaning and tidying up with the A/C on and didn't hear the pump. Later, I went inside, saw the switch light on. Reached under the step and placed my hand on it. HOT! Real hot. Must have been running for a good 2 or 3 hours non-stop. I shut it off and and let it cool. Put some water in the tank turned and it on. Seems ok, except it seems to cycle a lot more often now. So, how much life was taken off of it? Should I go buy another to keep on hand just to be safe? It's almost brand new. Not much use at all.
Seems like a good reason to not completely drain the FW tank again
2014 Northwood Wolf Creek 850
2005 Ford F350 SRW SuperCab/LongBed 6.0 Powerstroke
QuickTrick's Towing Tune
Torklift Tie Downs/Fastguns/Upper/Lower Stableloads
Rancho 9000's
24 REPLIES 24
wnjj
I went out to my shop one day to find the pump running. I had no idea how long but it had been weeks since I parked it. The tank was low, but not out and when enough water dripped from the faucet or evaporated it started up.
That was a few years ago and it still works but loses prime every time the camper is moved. I have to manually prime it using the winterizing valve. It could be just a coincidence.
Old-Biscuit
My GF has a very acute nose......if she smells anything I have to find it/fix it otherwise I don't get any sleep.
Good side.......no odors in 5vr batteries are not boiling, propane doesn't leak, all vents work, all water barriers work, all seals work)
Bad side.......she has a nose like a blood hound
joeshmoe
:B
Rancho 9000's
RZAR66
I blame it on the black tank too.
2018 Ford F-350 DRW
2024 Northern Lite 10-2
joeshmoe
The next time she wakes up from a dead sleep and says "what was that noise", I can tell her that it was just the hydrostatics within the camper working. Although she still swears that she smells gas. I tell her it's just the black tank odor. Go back to sleep. :Z :W
Rancho 9000's
RZAR66
My wife did the exact same thing. Water pump ran all day on an empty tank. This was 4 months ago and the pump still works as new.
2018 Ford F-350 DRW
ScottG
There are no impellers. The pump is a hydrostatic design - think of making arm-pit noises ;).
That's why it doesn't hurt it to run dry. There's nothing rubbing inside.
sabconsulting
If it runs dry could it wear the impellers so the system loses pressure back through the pump causing the pump to cycle occasionally?
Just a thought.
Steve.
'07 Ford Ranger XLT Supercab diesel + '91 Shadow Cruiser - Sky Cruiser 1
'98 Jeep TJ 4.0
'15 Ford Fiesta ST
'09 Fiat Panda 1.2
Old-Biscuit
They are designed to run dry.....doesn't need water to act as coolant. Diaphragms only move about 1/8" total.
Didn't get hot enough (motor) to trip.
Cycling more probably due to not getting all the air out of lines.......opening all faucets/showers (hot/cold sides).....toilet etc and purging lines of air.
It'll be OK
ScottG
Mine ran dry for more than two days - that was 5 or 6 years ago and it still works great to this day.
They are designed to run dry. I wouldn't worry about it.
