Sep-05-2014 01:22 PM
Sep-05-2014 07:25 PM
Old-Biscuit wrote:
From my reading of OPs initial post......
Noticed switch light was ON. reached under stair (where water pump is in TC) and it (motor) was HOT
Pump was turned on accidentally with no water in fresh water tank ("Seems like a good reason to not completely drain the FW tank again")
bobndot wrote:joeshmoe wrote:
Should I go buy another to keep on hand just to be safe ?
It's not a bad idea for the price of a backup pump to have on hand.
I spent more on gasoline having to drive out of the woods to go find a water pump than it would have been to buy both pump and regulator to have on hand.
A pump Flojet $45.00 and a regulator change-over valve
are two good backups to have.
You could always hold onto them to use on another rv down the road.
Sep-05-2014 07:06 PM
Sep-05-2014 05:58 PM
Sep-05-2014 05:36 PM
Sep-05-2014 04:31 PM
Sep-05-2014 04:28 PM
Sep-05-2014 04:14 PM
Sep-05-2014 03:26 PM
Sep-05-2014 02:52 PM
Old-Biscuit wrote:joeshmoe wrote:Old-Biscuit wrote:
My GF has a very acute nose......if she smells anything I have to find it/fix it otherwise I don't get any sleep.
Good side.......no odors in 5vr batteries are not boiling, propane doesn't leak, all vents work, all water barriers work, all seals work)
Bad side.......she has a nose like a blood hound
Surely, she must understand that these campers are constant work-in-progress. No matter how much preventative maintenance and repairs are done, errant odors and sounds are bound to sneak up at any moment.
7 yrs. FT..traveling weekly.
No odors cause the stuff that keeps odors out works and a multi-stage charging systems maintains batteries so they don't boil
Sep-05-2014 02:48 PM
Sep-05-2014 02:47 PM
Sep-05-2014 02:44 PM
Sep-05-2014 02:40 PM
wnjj wrote:
I went out to my shop one day to find the pump running. I had no idea how long but it had been weeks since I parked it. The tank was low, but not out and when enough water dripped from the faucet or evaporated it started up.
That was a few years ago and it still works but loses prime every time the camper is moved. I have to manually prime it using the winterizing valve. It could be just a coincidence.
Sep-05-2014 02:31 PM
