Sep-21-2014 04:23 AM
Nov-20-2014 08:31 AM
NinerBikes wrote:
Thanks Bigfoot, very helpful link.
Nov-20-2014 08:13 AM
Nov-20-2014 03:21 AM
Nov-19-2014 09:42 AM
Nov-19-2014 09:20 AM
Nov-19-2014 09:04 AM
Nov-19-2014 08:57 AM
NinerBikes wrote:bobman wrote:
I bought a wave three and in 20 degree F it wasn't enough so I bought a wave 6
no hose came with either of mine and FWIW it does need a regulator prior to the unit, so if you tap into the system prior to the existing regulator you will need one on the supply line
Thinking of tapping in on the low pressure side, with a 3/8" ball valve, maybe near the fridge, or oven, or cook top. Will know more once I see how it's all piped in.
Nov-19-2014 08:36 AM
AnEv942 wrote:HMS Beagle wrote:
...I would agree the CO is higher, though not much, much higher if the stove burner is working properly. The efficiency is about the same: no more heat is produced by catalytic combustion than open flame combustion.
Sorry but I am really confused, possibly you know something that I dont or my assumptions are just wrong about my Wave or ony other catalytic heater, unless were are talking different things here. If you were describing my Mr Heater Buddy heater I might concur to a degree. Though it does burn cleaner than our stove, I dont want to be in a small place long with it. But your stating that the efficiency of a catalytic heater is no better than the burner on my stove?
...same amount of propane for a given number of BTUs (heat)?
...same amount of unburned fuel and by-products etc. "fumes" released into air?
Curious
Mark
Nov-19-2014 06:04 AM
bobman wrote:
I used a hose with a quick disconnect on the wave unit and left the valve outside so any leak ( hasn't happened yet but valves do sometime leak at the stem as they wear) would not be in the unit.
Mines on a class B so I just place it on the sink cover at night and let it run all night.
I leave one window open on the end of the unit and the top vet in the ceiling open. My class B is a 3 season unit but with the wave 6 I can keep it comfortable warm in 20 degree weather. It probably has about the same interior cubic feet as TC.
I am going to sell it and get a true 4 season unit, kind of hate to because I spent a ton of money on upgrades before I figured out its not as well suited for my camping style as it could be. Someone is going to get a nice B from me, live and learn LOL.
Nov-19-2014 04:12 AM
Nov-18-2014 07:36 PM
805gregg wrote:
I just bought a Wave 3, I can't wait to install it, but the camper is on the truck and Lance has the propane lines on the bottom of the drivers side over hang, so I can't reach it until I unload, if we like it I will remove the power hungry, noisy, and propane wasting forced air unit, gain space and lose weight
Nov-18-2014 06:59 PM
Nov-18-2014 06:49 PM
Nov-18-2014 01:30 PM
