Jul-08-2015 07:55 AM
Jul-08-2015 01:14 PM
nomad297 wrote:
Just install a Reese Straight Line and your problems will be solved.
Bruce
Jul-08-2015 01:13 PM
sh410 wrote:
With the trailer weighing 4000# the tongue weight should be ideally 13% for best towing experience. Be removing 250# from the tongue weight that you stated was 550# leaving 300# or 7.5% increased the probability of severe sway, possibly more that the E-2 WDH can overcome.
The WDH that you purchased is much bigger than you need for the trailer that you have.
Here is the E2 installation Manual. It states that the tongue weight should be no less than 10% and no other sway control devise is necessary.
Jul-08-2015 01:12 PM
sew0177 wrote:yeah the front and rear both dropped between 1/2 and 1 inch, i dont recall the numbers right now, but it was well within the acceptable amounts based on the guide.
T3rry1,
I had that same WDH on my 33ft Rockwood prior to moving to a Class A. You said it was adjusted correctly ... when hooked to the trailer the TV would lower front and rear the same amount. When I hooked mine up, the friction of the bars on the L bracket attached to the trailer tongue was such that there was no way it was going to sway. I'm thinking the rain lubricated it enough for them to slip.
Jul-08-2015 01:11 PM
Dakota98 wrote:
OK, so you had 550# tongue weight before moving the batteries.
Was the WDH installed & being used when you had that 550# on the tongue ?
You indicated that you moved the batteries for security purposes & to lessen tongue weight.
If you were not using a WDH with the 550# tongue weight. I'd suggest putting the batteries back on the tongue.
At 4000 lbs TT loaded, 550# puts you at approx. 14% tongue weight, which is fine. Is 550# too much for your TV ?
Just curious, but why do you have 4-6 volt batteries ?
Jul-08-2015 01:09 PM
jayboogee wrote:T3rry1 wrote:
is there an option for the sway control on this setup? i didn't think there was since it was theoretically supposed to be built in, that's why i got this one to start with.
Looking at the stock photo you posted of your WD hitch, yes, there is, you can see to the right and left of your hitch ball, there are two more holes, where the smaller, friction sway control ball would screw into, then the sway control would hook onto an identical ball that would be drilled in horizontally to the side of the trailer frame. Exactly how i have it set up. Might be a cheap resolution for you.
The one piece of advice I can give when using friction sway control, is once you get off the highway, pull over and disengage/losen the sway control, otherwise it makes a loud metalic grinding noise during those tight secondary road turns! Freaked me out at first. Hah
Jul-08-2015 10:51 AM
RoyBell wrote:
Is trailer or a single or dual axle? Is it level when towing or slightly up/down in the front?
Jul-08-2015 10:17 AM
Jul-08-2015 10:11 AM
Jul-08-2015 10:10 AM
Jul-08-2015 10:04 AM
Jul-08-2015 09:54 AM
Jul-08-2015 09:35 AM
Jul-08-2015 09:18 AM
Jul-08-2015 09:16 AM
Jul-08-2015 08:57 AM
