Weight advice?
nodatset
I have a 2005 Silverado K1500 with a 5.3 v8 and 4.1 axle ratio. Manufacturer book says max tow weight is 8600 lbs. I want to buy a travel trailer...preferably 26ft.
What approximate "dry" weight should I be looking at? Besides features of the trailer, is there anything else I need to consider?
I want to go across the country and see it!
Soon to be retired,
Thanks!
11 REPLIES 11
APT
I recommend 5k pounds dry. That will be around 6k loaded for a week long trip whether is has 10k GVWR or 6k GRWR. From that era, the 4-spd transmissions really limited comfortable towing experiences compared to today.
Flush all your truck's fluids. Get a WDH with integrated sway control and a proportional brake controller. Happy Camping!
A & A parents of DD 2005, DS1 2007, DS2 2009
2011 Suburban 2500 6.0L 3.73 pulling 2011 Heartland North Trail 28BRS
2017 Subaru Outback 3.6R
2x 2023 Chevrolet Bolt EUV (Gray and Black Twins)
Lwiddis
โ€œSome trailers have 2000+ lb of cargo capacity,โ€
A reason I picked the Winnebago 2101DS...over 3,000 pounds of cargo capacity. Running at TV max and TT max is silly.
time2roll
Keep the trailer GVWR inside the tow rating for best results. And if you are close to the max do not expect to carry much in the bed of the truck. I agree with the 'forget dry weight' unless you are planning to haul empty trailers for a living.
coolmom42
Soon to be retired,
Thanks!
For a pleasant towing experience, start looking at no more than 80% of the tow capacity of your vehicle, for your loaded weight. So that is approx 6900 lb. Take off 1500 lb for "stuff" and that puts you at a dry weight of 5400 lb.
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
coolmom42
azdryheat wrote:
I agree, forget the term dry weight as it's meaningless as you will never use it dry. You want to know the maximum weight of a prospective trailer (GVWR).
Not necessarily.
Some trailers have 2000+ lb of cargo capacity, and many of us will never load that much stuff on a trailer.
If OP is travelling cross country on an extended trip, he will have a good amount of clothes and other stuff. I have the impression he is travelling alone. IMHO a single person would be hard-pressed to put more than 1500 lb on a trailer, UNLESS he/she is travelling with a large and full water tank.
Lwiddis
โ€œSounds great.โ€ Well, ok. Now we should discuss payload. What is your payload limit? What do you carry in the TV? Iracvet suggested keeping at 5000 max which is 650 pounds of tongue weight.
nodatset
Sounds great. I don't think I'll have too much trouble getting a 26' at or under 7500 lbs GVWR. Thanks for the tips! At least that's a start. I wanted to make sure I'm looking a the right size/weight trailer.
azdryheat
2013 Chevy 3500HD CC dually
2014 Voltage 3600 toy hauler
2019 RZR 1000XP TRE
Lwiddis
Don and I agree. Buy based on GVWR. Forget the mythical โ€œdryโ€ weight. And I too live in the West. โ€œMaxing outโ€ isnโ€™t fun.
donn0128
Do,nt worry about the mystical dry weight numbers. Every trailer built has a tag giving its GVWR. Look for it and pick one that is under 7500 GVWR. Traveling in the mountain west your going to even hate that much.
Iraqvet05
I would keep the dry weight around 5000 lbs. I towed our Jayco the first year with a 2007 1500 Silverado that had the 3.42 gears and found the truck to be a bit underpowered. Your 4.10 gear has an advantage but don't put a heavy load behind the 5.3.
2017 Ford F-250 6.2 gas
2018 Jayco 28BHBE
US Army veteran
