โSep-04-2017 05:48 AM
โSep-08-2017 11:24 AM
โSep-08-2017 10:57 AM
โSep-08-2017 10:15 AM
โSep-07-2017 06:24 PM
WNYBob wrote:
I think a WDH is a crutch when you don't have enough TV to do the job.
โSep-07-2017 03:09 PM
wolfpack30844 wrote:
Im a fairly new camper and TT tower. When using the weight distrubution bars how high up should you set it? Is it advantagous to set it as high as possible so the back of the truck doesnt sag down. I have a 1500 Dodge Ram and a 31 ft Coleman.
โSep-07-2017 11:25 AM
โSep-06-2017 05:20 PM
โSep-06-2017 05:13 PM
โSep-06-2017 04:58 PM
DutchmenSport wrote:
Unless you are having problems with your current rig set-up, why change anything.
However, if you are experiencing uncomfortable towing, the feeling that the steering wheel is floating and you feel you don't have good control of the vehicle and trailer 100%, then you should consider weight distribution.
If you decide to get a heavier camper with the same tow vehicle, yes, you will need WD then for sure.
Weight Distribution does 2 things: 1) it keeps the tow vehicle and trailer level to the ground, front and rear should be the same height. 2) it distributes the weight on the hitch to all points equal touching the ground. This keeps steering control, even wear on all your tires, and headlights from beaming at the moon.
โSep-06-2017 11:35 AM
โSep-06-2017 06:20 AM
โSep-06-2017 04:30 AM
rbpru wrote:
Let's see; the TT manufacturer recommends a WD hitch hitch, the TV manufacturer recommends a WD hitch, the vast majority of TT owners use a WD hitch, someone on an RV board thinks it it is not a good idea.
Hmmmm what should I do.
โSep-05-2017 05:25 PM
โSep-05-2017 02:42 PM
