Weight Police Help... LOL!!
SpknTC
Ok finally got the TC & Truck weighed... Uh how'd I do??
Michelin LT265/75R16 M/S2 and no additional mods. Rides Great!!
Full tank of gas & propane.
We were NOT in the truck (335 lbs) and fresh tank empty (18x8=144 gal.) = 479 lbs.
Jacks have been removed.
Out this weekend playing around...
Ford F450 6.7L PSD DRW 4X4
Arctic Fox 865
43 REPLIES 43
MORSNOW
Navigator II
Navigator II
Francesca Knowles wrote:
btggraphix wrote:
I'd bet dollars to doughnuts that dump truck is a dually.
I sure hope not...
Well the black water tank is over filled, no wonder. Or is that ballast to achieve perfect COG?
2014 Wolf Creek 850SB
2012 GMC Sierra SLT 2500HD 7,220# Truck/10,400# Camper Fully Loaded
Francesca_Knowl
I sure hope not...
" Not every mind that wanders is lost. " With apologies to J.R.R. Tolkien
jimh406
Bedlam, you need a Torklift GlowLadder for that application. They are made one at a time with optional GlowLadder carrier. I haven't found a supplier for the blocks, but I'm sure the jack manufacturers will create longer jacks soon using the larger 10 in diameter jack supports to handle the extra length. Finally, normal sized FastGuns will work, but it will be a week or two before Torklift finishes their tiedown mounts for that model truck. I hear it was hard to get one into their shop to do the measurements. See their application guide for more info. 🙂
'10 Ford F-450, 6.4, 4.30, 4x4, 14,500 GVWR, '06 Host Rainer 950 DS, Torklift Talon tiedowns, Glow Steps, and Fastguns. Bilstein 4600s, Firestone Bags, Toyo M655 Gs, Curt front hitch, Energy Suspension bump stops.
NRA Life Member, CCA Life Member
Bedlam
Moderator
Moderator
1. Is it OK to use blocks under the jacks when loading and unloading the TC?
2. How many GlowSteps do I need to order for this setup?
btggraphix
🙂 they should remove the jacks for better clearance too
2006 LanceMax 1191 - loaded and well-used
2005 C4500/Kodiak 4x4, GVWR 17,500
joeshmoe
Hey pal, we don't need facts and logic clogging the discussion up.:p
But seriously,:B... the COG is way behind the axle and there's probably not even a bed mat. What's gonna keep that thing from sliding around? And where are the tie downs? This is getting out of control. C'mon people. Do your research.
2014 Northwood Wolf Creek 850
2005 Ford F350 SRW SuperCab/LongBed 6.0 Powerstroke
QuickTrick's Towing Tune
Torklift Tie Downs/Fastguns/Upper/Lower Stableloads
Rancho 9000's
btggraphix
joeshmoe wrote:
Yeah, but it's still only a SRW. He's asking for trouble with that camper.
CptnBG
"Maybe here and here will help. Apparently in 2000 there was only a GVWR of 8600 while 9200 was for 3500 SRW. HD badge didn't start until 2001 I guess..."
Interesting reading. Regardless of what your truck is called, you have a good match, weight wise, and a nice looking rig.
'03 2500HD CrewCab SB 6.0 Gas 4x4
'04 Northstar Laredo SC
Bilsteins 5100
2014 1500 Silverado 5.3 Double Cab
1951 Chevy 3100
Formally OBXcamper
SpknTC
OBXcamper wrote:
jamminalong wrote:
billtex wrote:
That's amazing.
Our truck alone;2500HD Diesel CC is 7400#.
Hard to tell from the pic, is your truck a 2500 or 2500 HD?
Incredible there is that much difference between models...
Good job on keeping your numbers down!
Bill
If you look at the 3rd pic you'll see it listed as a K25753. I can't find anything about badges & HDs for that era. Plus from the other pic you can see I do have the camper cert. in the glovebox.
Jammin's truck has a GVWR of 8600 so I'm guessing a 2500. 2500HD is 9200 GVWR.
Arctic Fox 865
jimh406
mkirsch wrote:
No, it's need, or more precisely "*THINK* we need."
Corollary #1: We don't all think we need to put huge campers in our duallys, either.
I don't think I need a dually. I carried the same camper on a SRW, so I think your Corollary needs adjustment or you need more of them. 🙂
joeshmoe
Jfet wrote:
I think you need to upgrade the truck to handle the load.
Look at this guy with his camper and truck. He doesn't give a #$#@ about truck scales or weight police.
Rancho 9000's
mkirsch
Nomad II
Nomad II
jimh425 wrote:
OBXcamper wrote:
We don't all need duallys with giant campers with slideouts.
Minor correction, we don't need slideouts and drws we want them. 😉
CptnBG
jamminalong wrote:
billtex wrote:
That's amazing.
Bill
Bilsteins 5100
1951 Chevy 3100
Formally OBXcamper
SpknTC
billtex wrote:
That's amazing.
Bill
Arctic Fox 865
