โSep-01-2014 10:05 AM
โSep-03-2014 10:23 PM
7.3diesel wrote:Turtle n Peeps wrote:
#1 The lack of intercooler hurts this engine. (this can be fixed)
Which intercooler do your recommend? Banks looks expensive. Are there any other options?
Sorry, I don't have a recommendation for you. I can say get the biggest one that will fit no matter what brand or make.Turtle n Peeps wrote:
#2 The lack of HP really hurts this engine. (this can also be fixed)
The truck has a cold air intake on it, and I'm having a complete turbo-back exhaust with thermal wrap put on next week.
Cold air is not going to do anything for this engine. Save the money on the thermal wrap for a good intercooler or tuner. It won't do anything either.Turtle n Peeps wrote:
#3 The crank sensor can be problematic. (again, this can be fixed)...get a new spare crank sensor.
I wasn't aware of this. What does this do & where do I find one?
It tells the puter what position the crank and cam is in. Ford dealer.Turtle n Peeps wrote:
I would also think about beefing up the tranny. They were on the week side during these years and if you add some power you will do it in that much sooner.
The truck is a manual & shifts alright, although I haven't towed with it. But yeah, I might have to upgrade to a heavier duty clutch. We'll see how she tows with the stock clutch.
โSep-03-2014 08:49 PM
โSep-03-2014 12:25 PM
KTMsc wrote:
Adding a tuner made a huge improvement in power and firming the shift points, however as soon as I got in the hills, egts went up fast and had to switch back to stock setting.
The truck needs an intercooler to go with the tuner. Then you will be able to tow closer to the trucks rating.
KTMsc wrote:
Also it is the cam position sensor that fails, they issued a recall.
โSep-02-2014 02:29 PM
โSep-02-2014 10:11 AM
โSep-01-2014 11:52 AM
โSep-01-2014 11:17 AM
lawrosa wrote:
Its 10000 lbs for TT and 13500 for 5th wheel.. But thats with an automatic.. Thats per the tow rating list I found for your truck...
WE ASSUME YOU HAVE 3:73'S as all the 7.3 turbo diesals list this..
lawrosa wrote:
Want to know what you can tow??
Go weigh the truck with full tank of gas and you in it... Get seperate axle weights at a cat scale..
Post back those #'s with the axle weights on the door tag of the truck.
And post the tire weight ratings at max inflation from the side wall...
โSep-01-2014 11:13 AM
azdryheat wrote:
My last trailer was an Everest 5th wheel, 37 foot, that had a max weight of 14,000 pounds and a pin weight of 2000 pounds. I towed it just fine with a 2009 Chevy 2500 short bed with a payload of 2500 pounds. I did add Firestone airbags to lift the back end and Bilstein shocks.
The trailer I have now maxes out at 19,000 with a pin weight of over 3,000 pounds. I upgraded to a dually with a 5,000 pound payload, which handles the trailer with ease.
โSep-01-2014 10:42 AM
โSep-01-2014 10:19 AM
โSep-01-2014 10:15 AM
โSep-01-2014 10:12 AM
โSep-01-2014 10:08 AM
