โFeb-08-2019 11:03 PM
โFeb-13-2019 05:46 AM
โFeb-12-2019 07:26 PM
โFeb-12-2019 05:02 PM
Kayteg1 wrote:
When you are applying taxable ratings to physical truck ratings- you are ignoring laws of physics.
When you are applying gross truck payload to TC carrying capacity - you are ignoring laws of physics as with TC you can't use front axle carrying capacity. ... unless you put front platform and move some stuff from TC on it.
โFeb-12-2019 04:58 PM
โFeb-12-2019 04:52 PM
Kayteg1 wrote:LosAngeles wrote:
Last time I checked the F350 diesel was about 900 lbs heavier than the gasser, if i recall correctly, so that reduced the max payload by that amount. Does not work for us - as that *does* relate to carrying a pop up truck camper. Less max payload.
also we'll get the long bed, biggest cab F350 gasser, so 176" wheelbase. I'm no expert but that strikes me as plenty long, for safe driving.
Our 9.5' truck camper will overhang only 18" over the end of the bed. I think that should be more than fine. .
You still seem to ignore law of physics.
No matter the engine weigh difference, your limiting factor with TC is going to be rear axle rating.
Heavier engine on front can only help in handling, but will have no effect how much of TC you can safely load.
โFeb-12-2019 04:40 PM
โFeb-12-2019 01:35 PM
LosAngeles wrote:
what gas engine? 2020 F350: 6.2 Gas or 7.3 L Gas?
Hi all
Any guesses as to the increase in price from the 6.2 L gasser to the 7.3 L gasser?
If it was you (and you didnโt want diesel) what engine would you buy? the 6.2 L gasser or the 7.3 L gasser?
Our plan is to custom order a gasser 2020 F350 with just the options we want, and none that we donโtโฆ. and put a 9.5โ Hallmark pop on it full time. No, we will almost never tow anything. We hate towing.
โFeb-12-2019 09:13 AM
Kayteg1 wrote:
You are repeating common misconceptions here.
It is taxable payload that gaser has couple hundreds lb higher due to lighter engine, but that has nothing to do with carrying TC.
With long TC, who is having COG behind rear axle you can carry heavier camper on diesel, as with gas engine you will not have enough front load for safe driving.
Than gasoline v/s diesel engine is old wisdom.
"Pay me now, or pay me more later". It is a choice.
โFeb-12-2019 09:04 AM
brholt wrote:
Not sure what you are getting at here.
The payload of the trucks is higher on a gas engine than a diesel engine. If is is important for you to stay under the GVWR of your truck you are going to struggle with a diesel and many of the truck campers out there. Yes, the the diesels CGWR is well north of the 23,500 pound of the gas engine but for a truck camper? We aren't pulling a giant 5th wheel here. Our truck and camper loaded comes in at only 13,700 pounds.
Our personal experience with the 6.2 and the 6 spreed transmission carrying an AF1150 is that we could climb any mountain pass (for example Beartooth or Big Horns in Wyoming) at will and descend without using the brake. They engines may make less power at these altitudes but for a truck camper there is ample power reserve.
Why spend more for a more complicated and expensive engine when the gas works well?
โFeb-12-2019 08:20 AM
โFeb-11-2019 02:45 PM
JTLance wrote:
Funny, given the gigantic payloads of the newer trucks today, it's obvious to me, not deciding to buy a diesel is about not having enough money to afford one vs all the other reasons that people give.
It just seems intellectually dishonest to say otherwise.
If money is the reason, then say it.
If not, please list the truck camper that will only work on a gasser. (2019 going forward)
โFeb-11-2019 02:41 PM
LosAngeles wrote:Kayteg1 wrote:
Don't buy new models from first year of production.
New design engine and new design transmission. What could go wrong? ๐
Funny you say you don't want to worry about range, yet you are buying gasoline motor ๐
update - the F350 (longest one made - the one we will get ) - the gasser comes with a 48 gallon tank.
at 12 MPG that is over 550 miles. (and about 300 lbs of gas)
range will be just fine. ๐
โFeb-11-2019 11:31 AM
โFeb-11-2019 09:51 AM
โFeb-11-2019 09:36 AM
