May-15-2016 02:30 PM
May-28-2016 07:25 AM
myredracer wrote:
Can you post the brand and model of TT? Doesn't seem right. Tongue weights are typically around 10 percent based on factory dry wt. numbers and usually go up when it's fully loaded to average 12-13 percent, and for us almost 15 percent. It's hard to believe it's only 8.3 after fully loaded up unless "heavily loaded" is an awful lot of heavy tools or something in the rear of the trailer.
May-28-2016 05:57 AM
ssthrd wrote:lbrjet wrote:
The 220 lbs was shifted from the front axle to the rear axle and is not tongue weight.
The light just went on, but still a bit dim. So a weight distribution hitch properly set up will transfer the 220 pounds back to the front axle...... right?
OP--sorry to hijack your post. I'll just watch and learn here.
May-27-2016 09:31 PM
May-27-2016 08:59 PM
May-27-2016 07:09 PM
May-27-2016 05:02 PM
May-27-2016 04:17 PM
May-18-2016 06:36 AM
May-18-2016 06:13 AM
May-18-2016 05:25 AM
freetheheal wrote:I entered your weights using the same values for with WDH and without. It shows all of your calculations are correct. You might want more weight in the front of the trailer before adding the MC to the back.
Thanks mjbenedict, that's a great site.
May-16-2016 12:45 PM
May-16-2016 09:31 AM
tlukasavige172 wrote:
I don't have a WDH on the trailer.
May-16-2016 07:59 AM
May-16-2016 07:34 AM
