What is this plug for?
Tizi
This receptacle is in the compartment where by 30 amp shore power cord is stored. What is it for?
2008 Dodge Ram 2500 QC 4x4 - HEMI
2007 Northern Lite 10.2 RR
Tizi's Transformer by Whazoo
10 REPLIES 10
Ski_Pro_3
The other end of that outlet should be your genny. You fire up the genny and plug your shore power cable into it.
Gary3
Any Lance owner with a onan genny knows what that is comeon.
Gary  Lance  1191 solar Gen.
Bedlam
Moderator
Moderator
Yup, what NRALIFR said ^^^
It's an outie and not an innie.
Solar is connected to the DC voltage side of the camper this plug is the AC side.
Tizi
NRALIFR wrote:
stevenal wrote:
If this is really wired as an inlet, either for shore power or a generator; get it rewired. Energized prongs on the plug (male) needed to plug into this thing are not a good idea. Use a real inlet rather than the receptacle pictured.
Alternatively, it may just be a way to daisy chain another RV. Plug your TC into shore power and plug your travel trailer into the TC.
I think you're misunderstanding what the receptacle is for. If the camper has a built in generator, the receptacle (not the power cord) is the OUTPUT from the generator, and it's power is fed back to the camper by plugging the shore-power cord into it. That is exactly the setup my TC has. No transfer switch is needed, as the camper can only be plugged into one power source at a time: either shore power or generator power.
It's a simple, safe, and common setup.
I am pretty sure this must be the correct answer. My camper is wired for generator, but does not have it installed. I am wondering if I can use this to supply Solar power to the RV?
NRALIFR
2001 Lance 1121 on a 2016 F450 โ€˜Scuse me while I whinge.
And for all you Scooby-Doo and Yosemite Sam typesโ€ฆโ€ฆโ€ฆ..Letโ€™s Go Brandon!!!
stevenal
'18 Bigfoot 1500 Torklifts and Fastguns
'17 F350 Powerstroke Supercab SRW LB 4X4
Bedlam
Moderator
Moderator
Our toy hauler was set up that way with 50A service. It was easy to run the built in generator and power the house or shop tools off that plug.
RoyB
I would fire up your generator and use this pictorial to measure the 30AMP RECEPTACLE PINS and see what you read.
It might also be a user add-on coming from a high wattage INVERTER if you have one installed.
It is most likely intended to be able to plug your 30AMP Shore Power cable into it to power up your your 30AMP Trailer.
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
NRALIFR
If you have a built-in generator, then that's the AC output from it. You plug your shore power cord into it to power the camper. I prefer this setup to an ATS as it's one less thing to malfunction.
If you don't have a built-in generator, I'd say it's part of the pre-wiring for one and is not functional now.
donn0128
Generator plug in would be my guess. In place of an auto change over many RV's use a plug to connect your shore power cord.
