Apr-12-2016 09:41 PM
Apr-20-2016 11:07 PM
Apr-20-2016 08:31 PM
Lynnmor wrote:
Here is a cheap bearing, look after it all you want, it was made wrong. There is a ridge on the inner race that cut into the rollers.
Apr-20-2016 08:23 PM
Aqua-Andy wrote:
jfkmk and proxim2020, sorry I don't know how to multi quote so this will have to do:h. I can assure you that there is no magic behind a "permanently sealed" bearing. They use the same type of single lip seal that our trailers use. And that "lifetime supply" of grease that was mentioned? There is no special reservoir that supplies grease for the life of the bearing, I bet that most well packed trailer hubs have more grease than in the permanently sealed version. Our trailer hubs can be sealed just as good as a permanently sealed hub, It just takes a properly installed seal and some anaerobic sealer around the bearing cap. Permanently sealed and greased for life are nothing but marketing BS covering up for the lack of grease fittings or to make something sound better. Serviceable is always better! Take U-joints and front end components for example. The only difference between the two versions is the grease fitting. The seals and everything else is the same except in the non greasable version you got screwed out of a grease fitting. There is a company out there that makes a product marketed toward boaters that is interesting, it is a clear cap that presses into the hub and sealed with a sealer. The cap has a drain/fill hole in it, what you do is clean or replace the bearings and clean out the hub then fill up to the line (about half full)with 80W90 gear lube.
Apr-20-2016 04:32 PM
proxim2020 wrote:Aqua-Andy wrote:
Actually they do. If you disassembled that failed wheel bearing from your Avalanche you would find of all things, two tapered bearings filled with grease. The trick is they use quality parts and not Chinese ****. GM uses Timken bearings as OE. So replace your bearings with a quality product and use good grease, you should be good for years. Other posts claim there is a difference weather on a truck or trailer, there really is not.
The bearings are supplied with a lifetime of grease and are permanently sealed.
Apr-20-2016 03:26 PM
Apr-20-2016 01:51 PM
Apr-20-2016 09:24 AM
proxim2020 wrote:
Really you could get quite a bit of life out of the cheap bearings that come with these trailers if you look after them and keep them properly lubricated.
Apr-20-2016 08:55 AM
Apr-20-2016 06:35 AM
Apr-20-2016 05:39 AM
Skidus1 wrote:
I must be unlucky. I purchased my Open Range new in 2014 and didn't check anything and had no issues the first year. Last spring I noticed a little grease splatter on a wheel so I decided to check and had a seal had failed allowing grease to pass, replace seal and repack and also did the other wheel same side, no issues on that one. One trip later I was parking it and noticed one hub warmer than the other 3, Temp check showed 141 deg and others were around 118 deg. Pulled it and another seal had failed, caught it in time, clean up replace. This season no trips yet, I knew I had to do one wheel from the factory, same thing, no grease splatter on the wheel but the seal had allowed grease to pass and coat shoes. No idea what caused all this or if it's normal. I have the zerk fitting but have never used or would I use it.
Apr-20-2016 04:55 AM
Apr-20-2016 12:58 AM
Apr-19-2016 07:18 PM
LarryJM wrote:
IMO you might be playing a dangerous game of Russian wheel bearing Roulette since more often than not the amount of grease from the factory is woefully lacking.
Apr-19-2016 04:49 PM
Aqua-Andy wrote:SoundGuy wrote:
Interesting to me is the fact we're all still dealing with this nonsense. :M I've owned so many vehicles over many decades I can't even remember them all, yet I don't recall ever having to replace or even service the wheel bearings ... until recently. For the first time in my life a wheel bearing on the front driver's side of our 11 yr old Chevy Avalanche went south and had to be replaced ... first time this has ever happened to me. Surely by now the RV industry could install bearings that don't need yearly repacking and under normal circumstances won't fail during the lifetime of the trailer. :S
