Fixed Sight Training wrote:
In my '03 5.3 Tahoe I rarely floor. I keep the throttle steady and at 50ish I downshift to second and keep it about 3800 rpms. This is in the Rocky mountians and it seems to be very happy pulling at the high 3k rpm to 4k. I also hold it in second until I can let way off the gas and let it shift easily into third. My TH is about 6500 normally loaded and my GCVW is in the 12,500# range. I usually get just under 10 mpgs pulling in the mountains.
It seems like at 3400 rpms and less it starts to really struggle. It's always better for the engine to pull under load at higher rpms.
I think 3500 RPM is MIN any gas engine should be run at loaded in the hills. We have not towed more than a two horse steel trailer loaded with hay with our 5.3 but have put 18K miles on the MH 454 TBI engine and four speed transmission with a few thousand in the Rockies a couple years ago.
The wide open throttle up shift point is 4000 RPM. While the red line is more like 4500 I do not like to grind at over 4000 RPM which in 50 MPH in second gear I remember from pulling Grapevine going south in CA.
Any vehicle out of OD and in the hills towing loaded 60 MPH would be MAX RPM. Engines and transmissions are like men. Run them maxed out they do not last as long.
🙂While it is fine to run a GM transmission without the torque converter locked up (lock up feature was not an option until in the early 90's) it is not fine to climb below 3500 due to heat damage to the transmission and engine.
Going up to Mt Rushmore I was able to drag out some of those hills at 2800 RPM in 3rd but temps would start to climb but when going to 3800 in 2nd it ran cooler than at 70 MPH in OD in mid KS.
Manually downshifting (by going to the floor) then moving the shift lever to lock it into the lower gear works best for me where going up going up or down a big hill. If you have a newer 6 speed GM transmission the computer will do this for you when you down shift manually I noticed on a rental.
If one gives it more gas and there is not gain in speed/RPM and you are not in 1st gear then you are one gear too high.
Now with some V-8 and most all V-10's 4500 RPM may be the best RPM when loaded in the hills.
Again by taking off and leaving foot on the floor note the RPM of the automatic shift up point. This is your safe RPM when climbing or descending (engine braking).
Note we are only discussing GAS engines. Do not consider your MPH numbers when towing a load in the hills. It is only a by product of being in the correct gear and RPM range.
Higher the RPM is near the WOT shift point the less gas used and wear and tear on the engine and transmission I find.
Climb a mountain in a gear that more gas does not give more speed can cook a transmission over time.
