Aug-20-2018 01:13 PM
Aug-25-2018 03:42 AM
dodge guy wrote:Ralph Cramden wrote:dodge guy wrote:
It doesn’t matter if they are going by some updated rule! If they are using it to skimp on safety equipment then you know they are really skimping in other places. Actually now that we know they are skimping on safety that really questions the operation of Keystone!
And other manufacturers dont skimp, it's only Keystone skimping? They all skimp on both safety equipment and other things. They install the minimum required fire extinguisher. You would be lucky to put out a birthday candle with one of those things. They install the cheapest smoke and CO detectors that can be found. They install tires that are rated right at the max but only if you count X lbs as hitch weight. They put one screw where you need three, and the one screw is most likely stripped. All of the electrical items from a 12V switch to the radio or TV is the cheapest junk availible. The pleather used for upholstery may make it 5 years, I doubt it though, and the cheap foam will be crushed flat never to return regardless. The plastic faucets will wear out if you use them, actually they'll probably break in half, and everything plastic outside will deteriorate from UV damage in about 3 years.
All of them are skimping.....not only Keystone. When you look at sales numbers broken out by brand, Keystone outsells all the others in TT's and 5th wheels by a longshot, and has done so for years.....skimping evidently must work.
Yes, but when it’s so blatantly obvious and it’s a safety issue that they are tip toeing around that’s a problem. Yes others do to, but it’s non safety systems like tank gauges, materials and poor installation. When it comes to the consumers safety that’s where the line has to be drawn.
Aug-24-2018 07:25 AM
Aug-24-2018 07:11 AM
Aug-24-2018 02:32 AM
el.jefe wrote:
Follow up: I got a call from Keystone to answer my challenge that their design doesn't meet the standard. (I might have made that challenge on BBB yesterday).
By her explanation, they are technically meeting the standard by designating the sleeping area as attached to the living area and unobstructed to the main exit. So I guess I at least feel better knowing that they've done the absolute minimum they could do.
Since I've come this far, I might as well try to talk to somebody over at NFPA and confirm their interpretation.
Aug-23-2018 11:23 PM
Aug-23-2018 04:59 PM
el.jefe wrote:Trailer Life is a magazine that has a resolution center where you can ask for their help to resolve a issue.
What is Trailer Life? How do they resolve things like this?
Aug-23-2018 02:48 PM
Aug-23-2018 11:41 AM
Aug-23-2018 11:25 AM
Aug-23-2018 11:23 AM
Aug-23-2018 07:45 AM
Aug-23-2018 07:44 AM
Aug-23-2018 07:16 AM
Aug-23-2018 07:02 AM
