Mar-02-2014 12:46 PM
Mar-03-2014 07:29 PM
mbrianmills wrote:
I agree with those who say you will be OK. Yes, you will be at the max for your TV, but you already own it and you found the trailer you want. It may take you a bit longer to get to your destination because you don't want to push your TV too hard, but once you get to your destination you'll be able to relax in the rig you want.
I had an '06 Chevrolet 1500 which has a max payload of about 1800, but when getting rock for a retaining wall in our backyard I had over 2700# of rock in addition to my 4-person family in the truck and it did OK.
The point is that I was WAY overloaded and the truck was able to handle it. You will be at capacity (not overloaded) and your truck is designed to go up to that max. Remember that the max is a "rule" and like all rules I like to break them. You won't even be breaking the rules with this configuration.
Mar-03-2014 07:25 PM
Mar-03-2014 06:00 PM
Mar-03-2014 05:43 PM
Mar-03-2014 05:10 PM
brulaz wrote:
Argggh. This ^^^^. Payload does *not* take into account the weight of the driver.
Apparently GCWR or Trailer Tow Capacity does, dunno, don't care, because payload is usually the limiting factor.
Mar-03-2014 04:09 PM
Mar-03-2014 02:47 PM
Mar-03-2014 02:15 PM
Mar-03-2014 11:33 AM
Goldstalker wrote:dacotahkid wrote:JJ Spectre wrote:
That lower payload could be the dealbreaker, but let's see...
1552, plus 150 for driver, (payload ratings allow for full tank of fuel, all consumable lubes and 150lbs for the driver) so the way you are doing your math would give you 1702 total payload. Now:
1702 minus;
100 for Nerf bars;
100 for WDH;
465 for Occupants; and
975 for TW (might as well be pessimistic) equals;
62 lbs of available payload.
In other words, vitually nothing in the bed of the truck.
You are very close, but it sounds like it is within spec based upon what you've told us. If you think you can get everything you want to take camping into the TT you could do it. Keep in mind that 15% of GVWR for TW is a ballpark and it "could be" less.
As much as I'm a proponent of towing with 1/2 tons, I might be looking at a lighter TT so that I had the flexibility to bring along bikes, gernerators, toolboxes etc.
Good luck!
Wow this sucks, according to the TV manual they do not account for 150 lb driver in payload so if you add 150 to your math it is - 88. I guess the wife and I can go on diets!!!
Yes, they do give you the 150 so anything over that comes off your 1552. They also give a tank of fuel. Just load the trailer with everything not the bed of your truck and you will be fine.
Mar-03-2014 11:30 AM
1702 minus;
100 for Nerf bars;
100 for WDH;
Good luck!
Mar-03-2014 11:12 AM
Mar-03-2014 11:00 AM
1702 minus;
100 for Nerf bars;
100 for WDH;
Good luck!
Mar-03-2014 10:56 AM
Mar-03-2014 10:20 AM
