Winterizing question
nyokie
What kind of tape would you use to secure plastic over the vent for refrigerator on the external wall? I used clear packing tape today, but now thinking I might end up with some nasty residue to try and remove come spring. I duct taped all the gas and wiring and water drains etc underneath, but this requires taping on the laminated outer wall so thinking twice.
11 REPLIES 11
Wanderin_fool
My guess is if critters want in, plastic and tape wont deter them? I respect you trying prevention, but still check vents in the spring. I lit my fridge one spring and lit a squirrel nest on fire in my vent area. Lots of water and freaking out kept the camper from being a 4th of July firecracker. Funny how it was the 4th weekend,,,,
WD40 helps disolve residue in the spring. Goo Gone and those type of products tend to harden the residue where WD40 will disolve the residue and wipe off eventually.
Duramax/Lance 835
KTM/Arctic Cats
Motorized advocate in Colo. CMTRA, our local club.
www.cmtrail.org come visit!
Other Forums:
Thedieselplace.com ( chevsforever)
KTMtalk.com (xrcrasher)
Pontoonboating.com (Lounge Lizard)
Arcticchat.com (400crasher)
nyokie
excellent I'll grab some tomorrow thanks
MN_Ben
3M painters tape will do you well. Even if it gets a little wet. Be sure the area is dry when applying otherwise it won't stick at all. The adhesive is water soluble and the best thing the remove the adhesive residue, should some be left after removal but not likely, would be Windex.
3M makes other types of tape that would be better to suit this application but they are on the industrial level and would not be worth you time or money tracking down purchasing some for this little task.
Source- I'm a 3M QC Tech
2006 F350 Dually PSD
2008 Keystone Laredo 29RL 5th Wheel
2002 F250 7.3 PSD -SOLD
2004 Lance 1130 -SOLD
2005 Lance 981 -SOLD
2000 Lance 1010-SOLD
199? Texan 650 -SOLD
Ford FX4 Ranger -SOLD
nyokie
Okay i cover the lower snap out one with plastic and re installed but the top one has like 12 screws ill just leave it open
stubblejumper
Wrap with Saran wrap and just put it back in place as normal.
1999 Winnebego Chieftain
Wayne & Leila and Teddi (the Kid in the brown fuzzy pyjamas)
Sometimes I think the surest sign that intelligent life exists elsewhere in the universe is that none of it has tried to contact us.
WyoTraveler
I just leave mine open. When I'm ready to use my RV I inspect everything. Use air hose and clear out all dust dirt etc. Never had a probkem. Of course in WY nothing much is moving around in the winter except snow.
john_b1
nyokie wrote:
Seems a easy place for critters to crawl into? Mice or insects. Ya not sure if painters tape will hold up in moist conditions?
In. Nigh onto 50 years of Rving We have never had anything enter our Rvs through that area and almost anywhere else.1time in all those years a mouse. Jb
2001 F 350 CC PSD 373 rear,auto
RBW X16 slider,Bedsaver,Prodigy,Fold A Cover,Pressure Pro!
2011 Crossroads Cruiser cf32mk Patriot edit. 5th wheel Fibreglass and all the goodies necessary,Dish,comfy loungers,and a nickel to spend,
Mr & Mrs and the PUP.
nyokie
donn0128
I think you would be better off taking the vent cover off, place a piece of plastic inside and replace it using the cover itself to hold the plastic in place. But on the other hand I am not too sure why you want to do it?
ShapeShifter
old guy wrote:
painters blue tape? it is suppose to be non residue tape
But if it's anything like regular masking tape, the adhesive will dry out over the winter and then be nearly impossible to remove. Painter's tape is designed to be used short term and removed when the painting is done. Read the instructions and I'm sure you'll see that they don't recommend leaving it on any longer than necessary.
May I ask why you feel the need to seal up the opening? I never have.
2007 Holiday Rambler Endeavor 40PDQ LE
400 ISL Cummins/Allison
2013 Ford F-150 FX4 toad
Inside: Him, Her, and a pack of little furballs...
old_guy
