Wolf Creek 850 front box issues
anutami
The bolts that secure my truck bed to the frame have caused issues with my fiberglass. Although I have a rubber mat All the washboard roads have taken their toll.
Come to find out the bottom of my camper is only 1/8" thick!! I am looking for ideas on the best way to prevent further cracking to my fiberglass. Will installing a 1/2" thick piece of plywood help reduce the stress? I am looking at putting a sheet of diamond plating on the front to hide the cracks and possibly a piece of plywood on the bottom. Any other ideas?
Access panel, note the stainless steel band chewing into panel.
Also noticed the sides of the box structure are not aluminum, also note the 1 screw backing out
Front corner aluminum tubing, northwood claims these are stuffed with wood
2001 Ford F350 LB Diesel 4x4 CrewCab Stick
2015 Wolf Creek 850 Thermal Pane Windows, Oven, Reinforced Anchor Bolts, 200w Solar, Torklift Tie Downs, Fastguns, Stableloads
18 REPLIES 18
joeshmoe
Nice. I'll need you to come by and do the same to mine.
2014 Northwood Wolf Creek 850
2005 Ford F350 SRW SuperCab/LongBed 6.0 Powerstroke
QuickTrick's Towing Tune
Torklift Tie Downs/Fastguns/Upper/Lower Stableloads
Rancho 9000's
anutami
Also added additional protection and insulation to the wheel well access doors
tattoobob
Great job
2005 Ford F350 SRW 4x4
2000 Lance 1010
MORSNOW
Navigator II
Navigator II
Looks solid now! Good job
2014 Wolf Creek 850SB
2012 GMC Sierra SLT 2500HD 7,220# Truck/10,400# Camper Fully Loaded
anutami
Follow up on my fix, hopefully this will hold strong for a few more years at least. Will see how much I can beat up my camper this winter :0
Another look at the Support beams
Added reflectix, was going to add a see level system but the grey tank is too thin 😞
Plywood added with plasti dip coating
Reinforcements
Phew that was a PITA...
TxGearhead
I was worried about the corrugations in my truck bed not giving equal support. I cut 1/2" plywood in 4 pieces and completely covered the truck bed, including in front and behind the fender wells. I got the idea from some pics posted here. I put a rubber mat over the plywood. Hopefully there is nothing rubbing the bottom of the camper.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
mkirsch
Nomad II
Nomad II
That 1/8" material is NOT the "floor." It's just a belly skin to cover up the framing and any wiring/plumbing that runs under the floor. Not structural.
All the whooping and hollering and flailing arms in fake rage is completely uncalled for. Northwoods may have bad customer service, but they didn't cause the problem, so it's not right to blame them for it. This was caused by an odd bolt poking up, an inadequately thin bed mat, and hammering down washboard roads at inappropriate speeds.
silversand
1mtnman wrote:
I recently repaired a Hallmark that had a very thin sheet of plywood as that of your Wolf Creek. It had rotted over the years and was a poor design coming from the factory. I use 1/2 marine ply and 3 coats of Flex Seal. I applied the Flex Seal prior to installing the plywood and then just had to touch up where the screws into the frame were installed. If you haven't use Flex Seal it is a outstanding product. I then use aluminum angle to cover the outside edges.
.....I did exactly the same repair/reinforcement under our 2005 Outfitter (8 foot long tub). Most of the 1/8 inch lauan thin veneer ply rotted right off, exposing the aluminum frame and XPS foam block insulation between the aluminum joists. I had to strip off what was left of the rotted 1/8th inch lauan, yank out the several hundred staples from the aluminum (that was brutal to do, on my back, under the camper tub, with a pair of pliers LOL). Then, I coated 1/2 inch marine plywood with 3 coats of marine hull varnish (the 2 flat sides, and the 4 perimeter edges), then applied sealant to the exposed aluminum floor joists, and using hydraulic jacks, and bracing, raised the 1/2 inch plywood up to the under-floor, and compressed the new treated ply onto the underside, and screwed the new ply in place through the aluminum floor joists..I also caulked the joints where the several sheets butted together, and applied aluminum L extrusion to the whole perimeter of the tub....feeew. I don't want to have to do that again!
*On edit: ...our under-tub floor does not have access to any "equipment", nor does our under-floor cap any hollow pockets, so, as mentioned above, you may want to consider 3/4 inch plywood, and not 1/2 inch
Silver
2004 Chevy Silverado 2500HD 4x4 6.0L Ext/LB Tow Package 4L80E Michelin AT2s| Outfitter Caribou
SidecarFlip
Kayteg1 wrote:
It is not sometimes, it is always.
Each time you remove some skin from the camper you are for bad surprise.
I screw 3/4" plywood to bottom of my camper last season.
Don't think 1/2 will do much, unless it is high-grade multi-layer plywood.
That aluminium trim on the bottom is the stupidest and cheapest thing I can imagine.
For once you aren't 'whistling Dixie' with that observation.
They say 'beauty is only skin deep' and that applies in spades to TC's.
2015 Backpack SS1500
1997 Ford 7.3 OBS 4x4 CC LB
SidecarFlip
Artum Snowbird wrote:
How about something like this. You could get a welder to put together two pieces to cover the entire length of the bottom.
Aluminium plate
Would someone actually put that in their house, on the walls?? Not me, but that is a possibility for the bottom.
SidecarFlip
Even my cheap azzed Palomino is 3/4" plywood on the bottom. sheathed in embossed aluminum sheeting with roll formed steel flanged 'U''s running lengthwise and cross ways in the front and back. screwed to the bottom every 3" with flat head wood screws dipped in sealant.
The only thing that contacts the bed of my truck is the 'U' channels. The bottom is spaced off the truck bed by 1/2" I really like the 'U' channel arrangement. Keeps the bottom off the truck bed so no damage is incurred from our wonderful rough roads and the channels add a lot of stiffness to the camper itself. Hard to beat steel for strength where it counts.
Only downside I can see is the steel is slippery but that has never been an issue yet. In fact, I removed and modified the back cross channel to carry my Stow and Go step mount.
Artum_Snowbird
Aluminium plate
Mike
2012 Winnebago Impulse Silver 26QP
2005 16.6 Double Eagle
2018 Jeep Wrangler JK
previously Snowbird Campers,
Triple E Motorhome and Fifth Wheel
1mtnman
joeshmoe
work2much wrote:
I would send these pictures to Northwoods and ask for an explanation.
Why? They don't give a turd about you or whatever problem you have.
Rancho 9000's
