โJan-28-2014 07:15 PM
โJan-30-2014 05:58 PM
โJan-30-2014 05:56 AM
โJan-29-2014 01:54 PM
Nfrank wrote:I won't get side tracked into the merits of different methods of stabilization like this thread become..
I want to stop the rocking around on my 30ft Cougar and the two products I can find to help eliminate that are X-chocks and jacks stabilizer cross bars. I know both help, but which one helps the most? Has anyone tried both and can give a good comparison? Take a look at these two products I was looking to purchase:
X-chock
Jack Stabilizer
Thanks,
Nathan
โJan-29-2014 01:24 PM
Seattle Lion wrote:
Another inexpensive and useful fix is to put stabilizers under the extended slides. Dutchmen actually recommends supporting the extended slides for stays over a couple of days. You can get inexpensive supports and they take very little time or work to put in place.
โJan-29-2014 01:22 PM
Sandia Man wrote:
Some really good info about why/what causes trailer movement, but when I get to a campground I'm unwilling to spend more than but a few minutes leveling and stabilizing our 32' TT. Can't comment on the jack stabilizer the OP inquired about, but after leveling side to side we then install BAL chocks between wheels on both sides of our rig. Raise front of TT to remove WD/SC bars and unhitch from truck. Set powered tongue jack to an inch or two above level front to back. Lastly, we deploy BAL scissor and stab jacks mounted under the four corners of our TT using a power driver and we are as movement free as we care to be. Obviously we haven't removed every spec of movement, but we've reduced the majority if it and it feels pretty solid overall to us and that's all that matters. This simple process rarely takes more than 10 minutes tops as we have the routine down pack.
โJan-29-2014 12:47 PM
โJan-29-2014 12:44 PM
โJan-29-2014 11:04 AM
myredracer wrote:
I think a lot of how people perceive movement and what they do to reduce it depends a lot on the length of the TT, it's weight, axle ratings (spring strength) and the frame design. There are some frames on ultra-lites now that flex a lot vertically and they need to be firmly planted to the ground front and rear. (I know because we've seen it firsthand.)
โJan-29-2014 10:51 AM
โJan-29-2014 10:08 AM
โJan-29-2014 09:09 AM
โJan-29-2014 08:51 AM
Bob Landry wrote:
First, I'm going to to challenge someone to explain how X-chocks which do nothing more than allowing lateral movement of the wheels, do anything more than the plastic wheel chocks since the problem is essentially up and down force being applied to the suspension and the trailer frame.
โJan-29-2014 08:43 AM
LarryJM wrote:
several have mentioned jack stands at the corners and that is exactly where YOU DON'T WANT THEM. You need to get them close enough to the axles to get weight off the suspension and tires and reduce the unsupported frame lengths where frame flex is minimized. This is a balancing act that is dependent on each trailer, it's floorplan, and how it's loaded so this is where the experimenting takes place, but I contend there is an optimum placement that will give you a stability that can't be matched or even come close to with all the chocks and extra stabilizer bars you can install on your current system.
Larry
โJan-29-2014 07:55 AM
โJan-29-2014 07:28 AM
