ZEP Removal
stubblejumper
Anybody know what is used to remove ZEP? Was doing the M/H the other day and got some******off a shedding tree stuck in the fresh ZEP. Just want to remove the part that was affected and the re-apply. Also noticed one spot where I overlapped one of the rubber window seals causing a small black streak. Thanks all.
1999 Winnebego Chieftain
Wayne & Leila and Teddi (the Kid in the brown fuzzy pyjamas)
Sometimes I think the surest sign that intelligent life exists elsewhere in the universe is that none of it has tried to contact us.
3 REPLIES 3
1jogger
Previous posts regarding Zep mentioned ammonia based products wold remove as in windex.
I am going to use light ammonia mixture to remove it from one panel.
USARMYCW
Zep floor stripper will do the trick.
HappyKayakers
It's a floor wax so floor stripper should work. Be careful of overspray/runoff.
Joe, Mary and Dakota, the wacko cat
Fulltiming since 2006
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2017 Open Range 3X388RKS, side porch
