Sep-19-2022 07:47 PM
Sep-24-2022 07:09 PM
Sep-24-2022 05:37 PM
rtk2 wrote:
Solar is not complicated. Get a 12 volt solar panel (80 watts will suffice), get a cheap PWT charge controller (10 amps will work) and fuses if you wish. Mount the charge controller close to the battery (connect with 12 awg wire is fine). Mount the solar panel on the roof using Z brackets, then run the same 12 gauge wire and connect to the charge controller. That's it.
Sep-24-2022 12:06 PM
Sep-23-2022 05:39 PM
mkirsch wrote:StirCrazy wrote:mkirsch wrote:
Solar is quite an investment, especially if you install enough solar to handle charging from heavy battery use. That's assuming you have enough roof real estate.
The sun doesn't always shine either.
I don't know why people think it is such an investment, and what i heavy battery use? as long as your not trying to run an AC then it is far from an investment, well, maybe if you buy it from a rv dealership and have them install it for about 10X the price if you source and install yourself. for me it was haf the price to put my solar on than to buy a 1000watt honda generator.
Heavy battery use is running the battery down to minimum capacity overnight. Something VERY easy to do unless you are judicious about your use of the modern conveniences. Running the furnace all night, for example, instead of putting on an extra blanket.
Yeah maybe you can install some solar for 1/2 the cost of a Honda 1000, but you have to be a "solar nerd" able to design your own system right down to the wires, and you know all the secret places to get the components, cheap. Most people want a plug and play system.
Charging from the truck on the road costs $0, handles any level of discharge, and doesn't depend on the sun to shine.
Sep-23-2022 04:26 PM
Sep-23-2022 05:43 AM
Sep-22-2022 12:10 PM
#1Flyboy wrote:
Put a solar panel on the TC roof & your batteries will be charged on the road, at your camp spot AND when it’s parked at home…. My batteries are fully charged EVERY day by sunlight…….
Sep-22-2022 07:45 AM
Sep-22-2022 06:51 AM
Sep-21-2022 09:02 AM
Sep-20-2022 07:43 PM
Sep-20-2022 09:53 AM
Sep-20-2022 09:23 AM
Sep-20-2022 08:09 AM
