Honda generator to truck camper
GULFMAN
I have a Honda EU2000 I when using it to power my Bigfoot 2500 9-6 Do I need to use my surge protector like to do when Connected to a campground electrical pedestal?
Thank you
26 REPLIES 26
otrfun
deltabravo wrote:
otrfun wrote:
P.S. deltabravo, is it possible you were experiencing more of an issue with your generator lacking enough inrush current to start your a/c compressor, rather than an issue with the PI EMS?? Sounds to me like your EMS was simply doing its job. The voltage dropped too low when your generator was unable to provide enough inrush current to start the a/c compressor, so the EMS simply cut-off power??
Two things were at play:
1. The E2 error, which I could overcome be flipping the switch on the EMS remote, which bypass that error.
3. The other issue was the lack of ability of the generator to provide enough surge power to get the A/C fan and compressor started. When that happened, the voltage would sag and the EMS would kick off the power.
When I finally decided to jettison the EMS, the generator started the A/C just fine.
If I would have had a Micro Air Easy Start back then, it would have likely allowed the A/C to start from the generator with the EMS installed.
I so have a Micro Air Easy Start on my AF 992 truck camper's A/C.
What you're describing appears to be the same scenario posed in my questions.
Flipping the switch on the EMS remote to the off position does prevent the E2 error; however, it accomplishes this by turning off *all* protection.
Interesting enough, even with all protection turned off, the EMS circuitry itself will shutdown (opening the EMS relay, shutting off power to the RV) if voltage drops much below 95-100vac. This is not the low-voltage protection being activated, it's the entire EMS shutting down from lack of power. I would guess this is probably what occurred in your situation.
When you removed the EMS, it allowed the voltage to drop extremely low without interruption while the a/c compressor started. It says a lot about your Honda 2000, that even with this huge voltage drop, it was still able to provide enough inrush current to start the a/c compressor.
Yup, I agree, a Micro Air Easy Start would have prevented both the voltage drop and the resultant low-voltage cut-off you experienced with the EMS.
deltabravo
2009 Silverado 3500HD Dually, D/A, CCLB 4x4 (bought new 8/30/09)
2018 Arctic Fox 992 with an Onan 2500i "quiet" model generator
otrfun
deltabravo wrote:
Once upon a time I had a Progressive Dynamics hard wired EMS system in my AF 811.
It rejected generator power until I flipped a switch on its remote panel to disable one mode of its monitoring - open ground I think.
I always had to remember to flip that switch to use my EU2000.
One aspect of the hard wired unit that I despised, and a portable unit would surely do the same thing when plugged in to a smaller portable gen is this:
Any time my roof A/C compressor kicked on, the generator voltage would drop just enough to trigger the EMS unit to cut off incoming power (low voltage protect). When that happened, the compressor would of course be in a semi-locked rotor condition and would NOT start when the EMS re-enabled incoming power, so the voltage would sag again and the EMS would cut off power.
The ONLY way to get the generator to reliably run the A/C due to the issues with the hard wired EMS I had was to turn on my inverter, which would allow the inverter to carry the load of the A/C when the generator voltage sagged and caused the EMS to kill incoming generator power. Once the EMS re-enable incoming generator power, the inverter transfer switch would enable and switch off inverter mode and then the generator would power the A/C.
For the above reasons, I never recommend using a surge protector (portable or hard wired) when using a smaller sized portable generator.
I had my AF 811 for close to 11 years. About 3 years before I sold it, I removed the hard wired EMS and ebay'd it.
We've been using a hardwired Progressive Industries 30a EMS in our truck camper for the last 3 years. It's active, in-circuit, all the time, regardless whether we're on commmercial, generator (Honda 2200), or inverter (2000 watt) power.
A bonding plug is necessary for both the generator and inverter to prevent the E2 open ground error. The bonding plug consists of a male 120vac plug with the neutral bonded to ground which is plugged into the spare outlet on the generator and inverter.
We power our 11k BTU a/c via inverter/battery and generator (not at the same time) regularly and encounter very little, if any, voltage sag--certainly nothing that would trigger the EMS low-voltage cut-off. No doubt the Micro Air Easy Start installed in our a/c, which drops the LRA from 55a to <20a, is certainly a big reason for the lack of voltage sag.
The PI EMS works perfectly for us.
Bedlam
Moderator
Moderator
The fault issue with EMS is whether your generator has a bonded neutral to ground. Typically the generator is powering a RV or transfer switch at a home so bonding happens there rather than at the generator to prevent a ground loop and electrical noise.
They do sell bonding plugs for generators or yours may come with one. This is used if you are running tools or appliances directly off the generator so you have a safe return path during a short that will pop the breaker.
TxGearhead
^ This.
2018 Ram 3500 CC LB DRW 4X4 Cummins Aisin Laramie Pearl White
2018 Landmark Oshkosh
2008 Bigfoot 25C9.4
2014 NauticStar 21 ShallowBay 150HP Yamaha
2016 GoDevil 18X44 35HP Surface Drive
deltabravo
Grit_dog
Navigator
Navigator
zb39 wrote:
Not portable, but awesome..... I'm not sure anybody makes a liteweight portable diesel gen set.
I guess it would depend on your definition of portable.
The question was about portable gensets. Lots of things are awesome but not apples to apples.
zb39
2017 Host mammoth, sold
49 states, 41 National Parks, 7 Provinces
2019 2 door Rubicon 6 spd.
2019 Berkshire XLT 45B
2022 Host Cascade
2021 Ram 5500 Air ride
CA_Traveler
zb39 wrote:
I just looked at a ONAN 3.2KW diesel get set here at the Tampa RV show. 30.2 x 17.3 wide x 18 inches tall
Nice gen, definitely not portable.
2014 Grand Cherokee Overland
Bob
Grit_dog
Navigator
Navigator
Comes with remote panel and has its own fuel pump. Was at the ONAN display. They fired it up for me and it was quiet. Air inlet and exhaust out the bottom. Looks like a reg ONAN unit in a nice green box.
Around $5500 I think.
Would be great for my Ram 5500 and Host.
And?
Itโ€™s not a portable generator
zb39
2022 Host Cascade
mkirsch
Nomad II
Nomad II
valhalla360 wrote:
FireGuard wrote:
A little off topic but does anyone know of a generator like the Honda 2000 that is diesel powered?
No. Defeats the purpose. Diesel engines tend to be bigger & heavier for the same HP (aka: wattage) output.
These little generators are intended to be small and light.
If you are worried about gummed up carbs, look into propane adapters.
Don't forget LOUDER.
deltabravo
GULFMAN wrote:
I was just curious Iโ€™m in the high country of Tucson Arizona itโ€™s been raining since 10:30 So I tarped the trailer to keep the rain off the generator .
I built a generator tent
StirCrazy
Moderator
Moderator
Grit dog wrote:
No but Iโ€™m sure there will be 5 pages of debating it including a couple Karens complaining about hypothetical generator noise and a few posts about if you had solar and a certain type of batteries you wouldnโ€™t need a generatorโ€ฆwhich will spawn an argument about battery types and capacitiesโ€ฆ.lol
and look who started it on the second post haha
I do use a surge protecter, but not the ones you use when you plug in but a power bar one and its only formy electronics. don't know if I realy need it or not but it doesnt hurt.
2014 F350 6.7 Platinum
2016 Cougar 330RBK
1991 Slumber Queen WS100
