โOct-30-2011 11:29 AM
โFeb-09-2012 09:52 PM
Camper_Jeff_&_Kelli wrote:DAK
I just replaced the camper battery with this!
http://www.sears.com/shc/s/p_10153_12605_02850131000P?mv=rr#reviewsWrap
It's a monster and I can't wait to test it out with the furnace!
dak
I was looking at that DIEHARD PLATINUM Group 31 Battery too as an alternative to the Lifeline. It specs out about the same weight/performance-wise and has a three year warranty, plus is about 50 to 75 dollars cheaper each. Two of them will fit in my battery compartment easily and they do measure a little larger than the Lifelines. I'd like to know if it's Chinese or not?
Got any knowlege you've gained about them you'd like to share with the rest of us?
I read this on the SEARS website from the link you provided. It says the PM1 DIEHARD PLATINUM is made for SEARS by ODYSSEY.
purchased a PM-1 in May, 2011 to replace an Odyssey PC2150 for dry camping in our RV. The PM-1 is a high quality Absorbed Glass Mat (AGM) battery manufactured by Odyssey for Sears. The PM-1 is similar but not identical to the Odyssey PC2150. The PM-1 weighs 75 lbs while the PC2150 weighs about 78 lbs. Brand new the Odyssey measured 73 AH @ 13.02 VDC (with my Gold IBT intelligent battery tester) and the Diehard PM-1 only 34 AH @ 12.86 VDC. For my purposes the PM1 is plenty but only time will tell about durability. AGM has the advantages of being impact and vibration resistant with a very low self-discharge rate. I highly recommend a charger designed for AGM batteries like the DieHard Platinum Microprocessor-controlled Battery Charger ($90) or one of the high quality recommended chargers on the Odyssey website that cost more (e.g. ProNautic 1250, Odyssey OMAX-40AS-3B, Pro Charging Systems PS3, Charles 93-12405SP-A, etc.) A regular automotive type charger with 15 to 16VDC output will overcharge and destroy an AGM battery. One designed for AGM has an algorithm that limits the bulk/absorption charge to 14.8V with the trickle charge regulated between 13.5V and 13.8V. Your battery charger needs to be a minimum of 40 amps to properly refresh the PM-1. I believe using the 30A power converter in my RV was one reason my PC2150 didn't make it 4 years. See the three step charge profile under "Chargers" at odysseybattery.com.
Hope they work out well for you.
J&K
โFeb-09-2012 09:27 PM
DAK
dak
โFeb-09-2012 09:14 PM
2004.5 Ram SLT LB 3500 DRW Quad Cab 4x4
1988 Bigfoot (C11.5) TC (1900# w/standard equip. per decal), 130 watts solar, 100 AH AGM, Polar Cub A/C, EU2000i Honda
Toad: 91 Zuke
โFeb-09-2012 08:34 PM
โFeb-09-2012 08:18 PM
โFeb-09-2012 05:13 PM
โFeb-09-2012 04:00 PM
โFeb-09-2012 01:34 PM
โFeb-09-2012 12:30 PM
dakonthemountain wrote:Mello Mike wrote:dakonthemountain wrote:
I oiled the squeaky door on the camper, put the fresh food in the fridge, checked the tire air pressure and all the fluids on the truck, and patted it gently... We leave 9 hours on our trip to AZ !!!! Yahooooooo!!!!! ๐
Dak
Cool, Dak. Where are you headed?
We are headed to Hotevilla to the Hopi Indian Reservation (see my other thread where I asked you about Hwy 264..I've got different directions now and will be cutting almost 2 hours off the drive! ๐ )
dak
โFeb-09-2012 10:13 AM
Dak
โFeb-09-2012 08:57 AM
mountainkowboy wrote:
Finished mounting the new to me Atwood electric jacks on the S&S yesterday.
CB
Channel 17Redneck Express
โFeb-09-2012 07:58 AM
โFeb-09-2012 07:23 AM
Dak
โFeb-09-2012 06:38 AM
โFeb-09-2012 06:37 AM
