May-06-2019 04:00 AM
May-09-2019 11:17 AM
PenMan wrote:
I have the Garmin RV760LMT with up to date maps. All I have to do is turn it on and it will get me lost. I never really trust it now. I use a trucker's atlas to plan my route and use the GPS to look ahead for diesel, food, etc. My phone has a better map program. The last time I was on I40 going through Oklahoma City it kept telling me I had to exit as there was a low clearance ahead (I'm under 12 feet high). I noticed the 18 wheelers were not exiting so I decided to take a chance but the Garmin kept telling me to exit. It even got to a point where it had a screen pop up that made me hit a button to confirm that I was ignoring the Garmin directions. Made it all the way to New Mexico and never saw a low bridge. It has done similar mis-directions many times but this was the craziest. I still use it when on the interstates to look for services at upcoming exits. My guess is if you program it to go to Alaska you'll probably find yourself heading south into Florida as it takes you around the world to Alaska. When I want to get lost I program the Garmin to head to Dallas, Texas so I can find all the dirt roads on the way. I never trust it any more but use the trucker's atlas and it has never been wrong. The Garmin was wrong many, many times. Can you tell I really don’t trust the Garmin?
May-09-2019 09:17 AM
May-09-2019 03:44 AM
May-08-2019 10:41 AM
May-07-2019 09:27 PM
mkc wrote:
and it apparently doesn't factor in that RVs are not permitted on any parkway in NYS...
May-07-2019 07:28 PM
May-07-2019 02:26 PM
djsamuel wrote:Crabbypatty wrote:
Does RV Trip Wizard provide low clearance information? iI did not see that stated clearly in their docs.
It does flag low clearance areas on the map. To be honest, I'm not sure if it will route you around it or not.
May-07-2019 09:38 AM
May-07-2019 08:52 AM
May-07-2019 08:51 AM
RobWNY wrote:djsamuel wrote:RobWNY wrote:
RV Trip Wizard is the best in my opinion. I haven't figured out how to send the completed trip to my Garmin but the workaround for me is after I'm sure of all my planned stops for fuel and camgrounds, I recreate it manually on the Garmin. I do this in Google Maps as well and then send it to my phone so I have a backup just in case. RV Trip Wizard is worth the annual subscription price without a doubt.
You can export the trip from RVTripWizard as a .GPS file and import it into basecamp. There is more info here:
Export Instructions
djsamual, I've tried that several times. I can export it to basecamp ok but it doesn't upload to my Garmin for some reason. Obviously I'm not doing something right. I don't mind doing it manually. I have all the time in the world.
May-07-2019 07:14 AM
May-07-2019 06:26 AM
May-07-2019 05:44 AM
May-07-2019 03:41 AM
Thom02099 wrote:azdryheat wrote:
My Google Map says to go east from Twin Lakes to the 24 then north to I-70 then west the 82 then south to Aspen. It did not try to route me the short way.
Probably because CO 82 between Aspen and Twin Lakes is closed for the season and won't reopen until early June.
For the OP, the Mountain West Directory would be a good investment. It lists the restrictions on this, and similar roads in the mountain West.
