Hi,
You can get a GPS program by DeLorme Topo 10.0 (or maybe 11 is out now?) that you can plan a trip, then click to get the elevation changes along the route. It will give maximum grades up or downgrades. It is simple to change a route, and check the elevations of the new proposed route, and adjust your travels as desired..
However I still wonder why the worry about the grades? I know I avoided some just to save gas, but others worry because of fears of speeding down the hills out of control. Yet that is easy to take care of with proper equipment, and slowing down and downshifting to 2 gear if required.
I have been up and down highway 120 into Yosemite from highway 395. The "Pass" is around 9,500 feet elevation, while highway 120 / 395 interchange is closer to 2,500' elevation. There is a long 6% or 7% grade in between, and we decided to unhitch our tow car (Honda CRV) while going back to 395 to avoid to much heat on the brakes. By going slow, and shifting to 2 gear, we slowed the RV to around 35 - 45 MPH while using minimal amount of braking while driving.
The car came down the hill without any problems. By going slower, you give the brake disks time to cool off. If driving say 55 MPH, then you are going down the 1 mile grade in only about 1 minute, while at 40 MPH you will take about 75 seconds. That extra 15 seconds will allow the brakes to run cooler.
On one especially steep grade, from highway 395 up to Sherman Pass (11,500' elevation) I stopped about 1/2 way down the hill, and got out and took some pictures. That gave the brakes another 5-8 minutes to cool off before continuing.
Keeping the motorhome in 2 gear (out of 3 in that case) only allowed the RV to reach about 45 before reaching the maximum RPM near 3,800 RPM, and then apply a little braking pressure before letting them cool a bit, and keep going. While moving at 45 MPH, the air is going about 75 feet per second across the brake shoes and disk brake pads.
Leaving the RV or even your personal car in overdrive while going down a hill means that you will have to ride the brakes. It is so easy to shift down one gear or two, as needed to let the engine provide much of the braking, without needing to overheat the service brakes or disks.
Fred.
Porsche or Country Coach!
Kangen.com Alkaline waterEscapees.com
