Alamosa to Antonito CO via US 285
Vacationer04
How is it travelling down US 285? My main concern is grades. I will be in a 36 ft Holiday Rambler Vacationer gasser towing my '98 Cherokee. Speed is not a concern just steep elevation changes.
Thanks!
Jim & Linda E.
'04 Holiday Rambler Vacationer 36WDD, 2 slides
'03 Honda CR-V EX Awd
Demco Kar-Bar & baseplate
Brake Buddy Classic
"Don't tell me it can't be done, just tell me it won't be easy."
"If I can't buy what I need, I'll make it myself."
9 REPLIES 9
buc1980
Going down on Wolf creek pass be sure that you don't speed. I see 2-3 cops wait for customers and that not happen only one time.
2017 Ford F350 DRW,2005 Kountry Star 35ft,16750 lb weight on SAILUN tire,6 points LIPPERD Level-up.New Mor/ryde IS suspension install.Full body paint 2022.RV flex roof 2023
Vacationer04
Thanks for the advice. After some searching I found that there are three campgrounds in Antonito at about half the cost of KOA plus we won't have that long drive after a long day riding. I am not expecting glamour just a place to rest before heading out the next morning. I am prepared for Wolf Creek with scheduled stops to view and give the MH periodic breaks.
Jim & Linda E.
Brake Buddy Classic
BB_TX
Agree that Wolf Creek Pass will be more of a concern for DW as it is about 10,800โ€™. But it is a very good wide highway and she will be on the uphill side (assuming she is the passenger) most of the way rather than on the drop off side. Going west bound the climb up the east side is not as steep as going down the west side. The west side does have two lanes going down from the top thru most of the steepest decline before changing to a single down lane. So you can just stay in the right lane and go as slow as you want without holding up traffic. After that it is an easy drive to Durango.
You will love the train ride. If you havenโ€™t already bought tickets I suggest you take the train to Chama and the bus back. That way the scenery starts in the semi arid flat land and climbs into beautiful mountain passes and valleys for a dramatic change. And the noon meal was pretty darn good also.
There is a pretty nice KOA in Alamosa. Donโ€™t remember seeing anything in Antonito.
eubank
If you're heading west toward Durango afterwards, then you're concern should center on Wolf Creek Pass.
Lynn
Vacationer04
Thanks for all the responses to make DW feel better. We are only going as far as Antonio for the Cumbres & Toltec train and then back to Alamosa to continue west toward Durango. There is no decent place available to camp in Alamosa and it would also require an very early start, too. So we are going to stay at Antonio instead.
Jim & Linda E.
Brake Buddy Classic
sayoung
eubank wrote:
Alamosa to Antonito is flatter than a pancake. It's not very fast, though. That's agricultural country. You may wind up behind a tractor someplace.
Lynn
Antonito over to Chama,NM is another story if you plan on heading that way. Its a climb but pretty scenic.
BB_TX
As noted above. Flat easy drive about 30 minutes.
eubank
Lynn
2gypsies1
It's an easy drive.
Full-Timed for 16 Years
.... Back in S&B Again
