CG near Duke Cancer Center?
riven1950
I have to go to Duke for a week soon and we would like to stay in our TT rather than a hotel if possible. Daily treatments of about an hour so we need to be close enough to commute back and forth without a long drive.
We stayed at Spring Hill in Chapel Hill once when my sister was in the hospital there but it is a bit too far we think from Duke.
Closest thing we have found is Birchwood RV Park, but reviews are mixed. Newer reviews are better it seems. Anyone stayed there recently?
Also found a place called Triangle RV Park but not much info on it. Anyone know about it?
Other suggestions?
Thanks
7 REPLIES 7
garyp4951
Hope all goes well for you.
riven1950
Thanks for all the replies. Still not decided on what to do, but got some places to check out anyway.
FULLTIMEWANABE
Volunteer that worked at the centre in 2014 told us most extended visitors stayed at Birchwood. WM at that time also used to allow O/N parking = maybe worth checking out as a back up for an odd day or two in between.
FWIW: to others with family being treated under age 21, there is a Ronald McDonald House also.
It Takes No More Effort To Aim High Than To Aim Low - Reach For The Stars
huachuca
The NC State Fairgrounds CG is just off I-40 and about twenty miles east of the hospital - figure a half hour to forty five minute drive if you catch work traffic. Full hookups with 20 and 50 amp service.
Website
magnusfide
Here's the Allstays info on Triangle RV Park.
Triangle RV Park
"The only time you should fear cast iron is if your wife is fixin' to hit you with it."-Kent Rollins
First law of science: don't spit into the wind.
Magnus
Merrykalia
This may be the same campground that is mentioned above, but I think it's about 25 minutes away.
Rolling View Campground
2017 Ford F350 Crew Cab 6.7L 4x4 DRW
wanderingaimles
Falls lake state recreation area is about 15 miles.
https://www.ncparks.gov/falls-lake-state-recreation-area/camping
The Rolling hills campground there is open year round.
Edit, as per Merrykalia, I was referring to Rolling View.
Good luck with the process.
