โDec-28-2015 06:28 AM
โJan-23-2016 06:40 AM
โDec-28-2015 08:50 PM
โDec-28-2015 06:27 PM
โDec-28-2015 04:13 PM
โDec-28-2015 12:23 PM
โDec-28-2015 10:48 AM
โDec-28-2015 08:35 AM
4runnerguy wrote:
First, 5 years old is pretty young for the length and physical stamina required for this endeavor. If you plan on camping, that's a lot of weight to haul. I don't think you could carry your 5 y.o. plus a full pack also. Remember, this is like climbing a 5000' high mountain, except you do the descending first and the climbing last in an extremely hot and dry environment.
You might consider staying in a cabin at Phantom Ranch instead of camping. They also will haul your gear to the bottom via burro if you are staying at the lodge (for an extra fee, of course). Check out the rates here.
Please be aware that this in no trip to take in the summer, especially with kids. Temps at Indian Garden (part way down) average 105 degrees and at Phantom Ranch the average is 115 degrees. The hike out is rigorous to say the least, and the sun is brutal at those temps. We've done this hike in late March and early April, and it was still in the mid-upper 90's at the bottom - plenty hot. With kids, this is best done as a spring break hike.
We've gone to the bottom a couple of times as day hikes (not recommended by the NPS, but we were in our 40's and in great shape). We took the earliest shuttle bus out to Yaki Point and hiked down the South Kaibab Trail (7 miles). After soaking our feet in Bright Angel Creek and having lunch, we hiked back up Bright Angel Trail (9.5 miles). I would recommend this trail for the ascent as you can refill your water at Indian Gardens. Seasonally there is also water available at 1 1/2 mile and 3 mile rest houses. Another nice thing about the Bright Angel trail as the return route is that the upper part is in the shade of the canyon rim in the afternoon, which makes hiking much cooler that going up via the full sun of South Kaibab Trail. We were on the trail for around 10 hours, including an hour or more at the bottom cooling off in the stream and eating.
One more positive about returning via the Bright Angel Trail: if you get back to the rim by 5:00 p.m., you can stop at the Bright Angel Fountain and have a triple scoop of what ever ice cream you want. You've already burned off all those calories climbing up from the bottom! And you'll still be hungry for dinner.
Again, don't underestimate this trail. We've climbed multiple 14,000' peaks here in Colorado and I used to do field work in the Nevada deserts, hiking 10 or more miles a day in the summer heat. Even I would say the hike is grueling. Maybe you should wait a few years until the kids are a little older.
โDec-28-2015 08:14 AM
โDec-28-2015 07:26 AM
โDec-28-2015 07:08 AM
