We camp all the time up on the SKYLINE drive and do just fine. I am already setup however with additional batteries and will run my 2KW generator each morning when allowed to run it to recharge my battery bank. My battery bank drops down to around 12.0VDC around 8Am in the mornings after running a pretty heavy drain on then from the 6PM to 11PM time frame.
My trailer is setup with LED lights and has the smart mode PD9260C converter/charger unit installed to maintain my batteries. I plug the trailer directly into my 120VAC receptacle on the 2KW Honda Generator using a RV30A to 15A long adapter from WALMART.
We always camp at the other end of the skyline drive at LOFT MTN. The Big Meadows in the center wa always too full of people for us. Never camped at Mathews Arm but have visited it a few times. It is the smallest of the three main camping areas.
Another really good spot just off the Blue Ridge close to the SOUTH END of the SKYLINE Drive is a place called SHERANDO LAKES that is a really great camping spot. It has both NO HOOKUPS and also electric sites...
All of these places were first built for TENT CAMPING along the SKYLINE DRIVE and BLUE RIDGE PARKWAY and for me I'm glad they have stayed with the NO HOOKUPS. We are avid TENT campers from back in the early 60s and this is where we go to do this style of camping.
Our back up heater for the POPUP is one of those MR HEATERS propane canisters type. As long as you use this in a vented fashion they are safe to use. I crack open the sky VENT on my POPUP trailer and it sits right under it on a shelf arrangement. I also have to sit it in a metal tray of some sort as alot of water gets generated from burning the propane. Some folks will not even think about using the MR HEATER Propane heaters as they are dangerous to use in an air tight trailer. You just don't wake up the next morning...
You will be just fine with blankets... we enjoy that as well...
Makes that first cup of good ole fresh ground and brewed BEAN COFFEE taste sooooo good...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
