โNov-30-2013 04:37 PM
โDec-01-2013 06:43 AM
B.O. Plenty wrote:Yea, I beg to differ, I have one of those 12volt compressors and blew out my water lines with it. My TT is a 26ft box which is a little bit larger than the op's class c 24ft (according to his signature) and it did the job for me. Now normally I don't use the 12 volt,I do have a 100psi 3gallon compressor that I use, but the wife wanted to go camping this past holiday weekend and it started getting real cold so I had blow my lines before it was to late. With no power available at the storage yard, I had to go with the 12volt using my truck 12 volt receptacle. Like someone stated in an earlier post you can use a bicycle pump, you just need to have the correct volume of air to push that water out.
Maybe it's just me, but I doubt that little 12 volt compressor will work very well to winterize. It won't have a high enough volume of air to really blow anything out..But maybe somebody else has a different opinion???
B.O.
โDec-01-2013 06:36 AM
Bumpyroad wrote:
HUH, didn't know they made such a thing.
bumpy
โDec-01-2013 06:22 AM
K Charles wrote:
You can blow out the lines with a bicycle pump. Even if you don't think that will work, which it will, it will be good enough to get you home.
โDec-01-2013 03:29 AM
โDec-01-2013 02:57 AM
Francesca Knowles wrote:
I presume your rig has a trailer light connection at the rear- there are adapters that you can plug right in for 12volt power. Here's a link for the seven-pin style pictured below.
โNov-30-2013 06:20 PM
โNov-30-2013 06:00 PM
โNov-30-2013 05:49 PM
โNov-30-2013 05:34 PM
pianotuna wrote:
Hi,
The motor in the compressor won't be too happy about the voltage drop from a longer cable.
Lew
โNov-30-2013 05:32 PM
โNov-30-2013 05:15 PM
โNov-30-2013 04:55 PM
B.O.
โNov-30-2013 04:51 PM
โNov-30-2013 04:49 PM
