RC Flying Club in Quartzsite?
Jerry_Campbell
Anyone have any info on the club.
I have been to the field but there is never anyone around.
Thanks
Jerry
10 REPLIES 10
SCVJeff
Jerry Campbell wrote:
Thanks Jeff,
Good luck with the firmware update.
When do you think you will get here?
Jerry
Friday (mebbe Thurs) before the show.
Better make sure I have a spare set of props. I doubt I'll find these anywhere within 200 miles
Jeff - WA6EQU
'06 Itasca Meridian 34H, CAT C7/350
Jerry_Campbell
Thanks Jeff,
Jerry
SCVJeff
From what I've read, most flight controllers have had similar issues.
I have not been able to afford a Naza. I have a Rabbit I and two Crius AIOP's one V1 and one V2.
The V1 is on a DJI 450 Clone and the V2 is on an 550 alien/dead cat frame that I'm building.
Too much fun. I also have a 32" wing.
Living in a bus limits the size of everything.
The new firmware is now apparently fast and smart enough to take care of a failed engine or spun prop on the Hex with essentially no affect other than payload is reduced. I'll probably load and flight test out in Q. Don't think I'll have any time before that
Here is the guy in Q that looks like he's moved. But he will know whazup with the field:
DXSTICKMAN
Jeff - WA6EQU
Jerry_Campbell
SCVJeff
SCVJeff wrote:
If you're on the RC Groups forum, post this question there as well. one of the Quartzsite residents and his wife (the club treasurer) are very active there and will likely respond directly.
He did for me.
Thanks Jeff, I have been on RCGroups for a couple of years. Mostly on MultiRotor Electronics. Which forum did you ask on?
Thanks
Jerry
Don't remember, I think it was that one. Lemme go back and see what I can find.
I have an F/550 I'm bringing, but need to update the FC firmware. DJI had so many problems with random fly-aways I chickened out for almost a year.
Jeff - WA6EQU
Jerry_Campbell
He did for me.
Thanks
Jerry
SCVJeff
He did for me.
Jeff - WA6EQU
tempforce
if you don't have any luck in quartzite, head east to black rock r.v.
they have a nice field... (i helped build it).
somewhere in the texas 'lost pines'
currently without rv.
'13' Ford Fusion
'83' Ford Ranger with a 2.2 Diesel.
'56' Ford F100, 4.6 32 valve v8, crown vic front suspension.
downsizing from a 1 ton diesel and a 32' trailer, to a 19-21' trailer for the '56'.
Jerry_Campbell
Thanks Harold
harold1946
Quartzite Desert Flyers Club
PO box 4554 Quartzite Az. 85359
928-927-3420
Harold and Linda
2009 CT Coachworks siena 35V
W-22 Workhorse 8.1L
Explorer Sport toad
