Wisconsin Adventure...
pconroy328
Something a bit unplanned for us, next week is Spring Break and because of some family circumstances we're heading for Southern Wisconsin area (around Lake Geneva) in our RV.
Every campground is closed, so we're trying to see if we can put our Class C (a Jayco 31FK) in front of a relative's home. But it would be nice to have a Plan B.
Anyone up 'dere in the Great White North have a suggestion?
I'm a bit worried about electric (think we can get by with 20A) and where to get the propane refilled.
Looks like had we be able to wait a week or two, a few campgrounds would have been open. But we can't.
thanks!
7 REPLIES 7
AJR
Not close but open. Just go up RT. 47 once parked. At this time of the year they put me in a pull through. Off of I90.
http://www.lehmanrv.com/
2007 Roadtrek 210 Popular
2015 GMC Terrain AWD
rockhillmanor
Did you 'call' any of them? Ya their websites will state when they open for spring etc. but most stay open all year.
Almost all of the CG's are open but the water is not turned on. You will have electric and dump hookup. Most have bathrooms that are heated so they leave the water on in them. you can shower there. It's best just to pull in these CG's and they will let you stay. If you call they'll say they are not open.
Call Coachman's in Lake Geneva. Small but nice and Lake Geneva is just down from it. If you look it up on line it will look like a mobile home park. But there is a section in the middle that is for RV campers.
I stayed there every summer when I was traveling! :C
kknowlton
Agreed on Chain o' Lakes. It was open in late March in 2011 (when we stayed there for a night.) No water, but the pit toilets were open, and so was the dump station. Electric hookups (30 amp available; possibly 50? haven't been to that CG in 6 years.)
2020 Toyota Tundra CrewMax 5.7L V8 w/ tow pkg, Equal-i-zer
2020 Lance 2375
Mortimer_Brewst
You might want to check to see if the nearest Menards has propane. They recently added the service of refilling tanks.
I've never stayed there, but Chain of Lakes State Park in northern Illinois might be open. It's about 30 minutes from Lake Geneva.
If ethics are poor at the top, that behavior is copied down through the organization - Robert Noyce
2018 Chevy Silverado 3500 SRW Duramax
2019 Coachmen Chaparral 298RLS
Snowman9000
Any propane business should be able to take care of that worry.
Also, some Menards home center stores have vehicle propane dispeners in the parking lots.
Currently RV-less but not done yet.
DCS7
We just stayed in my parents driveway in Racine early in March. We plugged into their electric with a reducer and just used the lights and propane for heat.. There is propane at Burlington RV at the Racine, hwy 20 exit.
doxiemom11
We used a 110 plug in at my brothers and got along fine. We are a 50 amp motorhome. We just used propane for the water heater and frig. Didn't need heat, but could have used A/C. Instead we used the ceiling fans with windows open and had a floor fan rotating- moving air seems cooler. In your case you can use your furnace for heat. Just be mindful to not use many thing at once.
As far as filling propane, do a google search when you get there, or you could do a tank exchange if you use 20# tanks. If an onboard tank you can do an extend a stay and then use the 20# tanks which are easy to refill/exchange. Many grocery stores, hardwares etc have that. Some gas stations have propane fill as well as farm coops. Or, if you drive by a large propane dealer they usually will fill for you. Many of the Flying J truckstops have on board tank fills available.
