921 and 1156 LED Upgrade FAIL
jamnw
I purchased these and these to put in my new camper. They do not put out enough light.
Any recommendations?
Thanks
MARRIED WITH 2 BOYS: AGES 11 AND 13 years!
2000 F250 PSD/CREW CAB (301000 original miles)
2014 Keystone Springdale 320FWFBH
USN Veteran, Aegis FC
10 REPLIES 10
tenbear
Five 5050 LEDs will not supply much light. You need at least 18 and 24 would be brighter.
2010 Subaru Impreza Sedan
Shadow_Catcher
All of our fixtures are marine and use a standard G4 pins. I have used one side SMD's. All of the light goes where we want it.
Retired_JSO
RV Geeks did a total LED conversion. Can get the links and such from here.
RV GEEKS LINK
BarneyS
I replace all the ceiling lights in my trailer this past winter with these.
In addition, I replaced the regular bulbs in three fixtures with these cob style lights. I am very pleased with the color and light output. It is almost identical to the regular bulbs in color but a bit more light output.
Barney
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
coolmom42
ledtrailerlights.com
Single empty-nester in Middle TN, sometimes with a friend or grandchild on board
westend
The first linked LED doesn't have many LED's so will be dim. The second one purports to be 800 lumens, that's a lot of luminescence, equivalent to a 60W incandescent.
A search on th Forum will turn up many threads about LED's. FWIW, I installed 48 1210 SMD panels, bought from an ASian seller on E Bay. I'm real happy about the result and the price.
'03 F-250 4x4 CC
SoundGuy
See my recommendations in this thread.
2012 Silverado 1500 Crew Cab
SteveB
Check out diodedynamics.com. Not cheap but they work. I put a set of 924 fog lamp replacements in my Challenger. Very bright and useful light.
2015 RAM 3500 CTD Auto 4X4 CC Dually, Reese 20K
SOLD 8/2015 '01 Dodge Ram 3500 CTD HO 6sp, Reese 15K Pro w/ Kwik Slide, Prodigy
'04 Jayco Jayflight 28.5RKS
jamnw
This was for inside the camper. Not on my truck.
boogie_4wheel
I did 1157 amber LEDs on the front of a '97 GMC truck I had. The light output wasn't quite as bright as the incandescent bulbs, but it was close. They were in clear housings.
Only place I've ever got LEDs that I wanted to matter, was from SuperBrightLEDs.
Here is a link to what I used on that truck.
1157 Amber
This was a few years ago, and there are many more options available now. Look at your mounting depth, and how the socket is arranged (directly in the back, to the side), and do you have a reflector in the light housing that radially mounted LEDs could shine off of. You could also stick in some alum foil to reflect light from the backside.
2005 2500 Cummins/48RE/3.73, QCLB, 4wd, BigHorn, Edge Juice w/ CTS + Turbo Timer,Transgo Shift Kit ISSPro Oil and LP pressure gauges, GDP 20/2 filters, Custom Diesel Steering Box Brace
'10 Forest River Shockwave Toy Hauler 21'
Honda EU3000I Genny
