Added basket shelves in tall closet
TheWB
Lot of unused space in this back closet. Had a shelf at the very top and that was it. We used it for the garbage can and brooms and paper towels up top. These basket shelves really added useful storage. We keep dry goods in there now. I attached wooden supports to the walls, then used screws with large heads to secure the wire of the baskets to the strips of wood. Very secure.
6 REPLIES 6
TheWB
DutchmenSport wrote:
GordonThree wrote:
Nice work! I'd like to add shelves to a "wardrobe" I have in my TT but I worry the screws would work out of the paper thin press-board they use for walls as my tiny tt bumbles down the road.
Have you considered add a strip of white LEDs running up the inside, behind the door trim?
TheWB did a nice job there.
GordonThree: Even if you are concerned about flimsy walls, you could still do similar. Put a bead of Liquid Nails on those support boards and then screw into the wall. It will never come off, even on thin paneling.
If the cabinet is lined with wall paper, score the wall paper right where those boards will attach. Then peal the wall paper off before using the Liquid Nails so it's gluing the wood to the panel, and not to the wall paper. This will make the shelf much stronger too.
Spot on there. What one might not be able to notice from the pictures is that the wire basket has a lip. It is this lip that is supporting the weight of the wire basket and the lip sits on that piece of wood. The large head screws make sure the basket lip remains on the wood.
RoyB
What would we do without wire baskets...
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
nineoaks2004
Good idea, should give more storage space..
By the time you learn the rules of life
You're to old to play the game
DutchmenSport
gbopp
Nice . It's a good use of basically wasted space.
GordonThree
2013 KZ Sportsmen Classic 200, 20 ft TT
2020 RAM 1500, 5.7 4x4, 8 speed
