Reflective Caution Tape
allenm
After almost getting rear-ended by someone not paying attention (I was in the far right lane), I decided to apply some self-adhesive reflective tape to the rear. Don't know if it will help, but it sure won't hurt!
23 REPLIES 23
kgragert
If you're in Florida, the FDOT and DOT requires Red/White on the rear of vehicles.
We had to change all of our vans that had the yellow/white.
Had 40+ vans with yellow/white for years until an FHP Trooper pulled one of our vans over and gave the driver a warning ticket.
And a big Plus for 3M reflective tape, brightest tape out there.
I thought when I retired my Hobby would be RVing.
I was wrong, my Hobby apparently is Finding and stopping leaks.
allenm
Seems the NHTSA/DOT requires red & white on all large commercial trailers.
This article describes proper size, placement, etc.
http://www.seton.com/blog/2014/01/reflective-tape-regulations-what-you-need-to-know
So, I've removed the yellow/black tape and bought some DOT approved red/white.
I understand what some replies have said about some people on the road running into emergency vehicles with their lights flashing. As someone said on a late night show - you can't fix stupid...
In any case, NHTSA/DOT says the reflective tape reduces trailer collisions by 29%. I'll take that over a nice looking back-end that I can't see anyway.
JaxDad
Newer vehicles have much better headlights than older ones had, part of that is a much more precise beam of light.
Putting reflective material up high won't accomplish much since the headlights won't be pointed up that high and won't reflect it much if at all.
To be most effective reflective material needs to be within 36" of the ground.
JimBollman
I'm sure there are other good reflective tape manufacturers but this is a case where you don't want to cheap out, big difference between cheap and really good tape. Years ago I had a retired Ohio Highway engineer tell me to only buy 3M reflective tape, that it was the best and that is what I have on all my trailers and a strip visible under my slide in camper on the truck. The tape lights up like it is a powered light when any light hits it, much more attention getting than any lights or small reflectors that you can add. On his recommendation I have orange/white stripes the full length of my trailers, low on the sides and red/white stripe across the back, again low. Higher would probably be better but this is a compromise between appearance and visibility. You see the stripes much sooner than you see what they are attached to.
johnwalkerpa1
downtheroad wrote:
My take on this:
If someone can't see the back of a full sized RV, then reflective tape isn't going to help...
Yep, I sort of had the same thought...But, that being said..I did replace my tail lights with LEDs....Mine were not very bright, especially in the rain or fog...makes a huge difference in rear visibility at night...
spike99
I apply reflective tape on the rear of my many different utility, boat and RV trailer as wells. I install near eye level - so their own headlights reflect back at them (when they follow too close). Haven't been rear ended since. Thus, I know this proactive safety tool works. As for my trailer's looking like a christmas tree or construction trailer at night? I cannot see my trailer's rear when towing it. Thus, high reflective tape vs someone's super bright lights doesn't bother me at all. giant smile.
colliehauler
I used the red/white reflective tape from Tractor Supply on the bumper of my TT. I don't know how people can not see a small house in front of them but like others have said people run into the backs of emergency vehicles with their lights going all the time.
spoon059
allenm wrote:
I'm in Melbourne, FL for the winter. It was sunny and 88 here. Yeah, it looked pretty nasty back home in B-Town today.
I hate you...:p
2015 Ram CTD
2015 Jayco 29QBS
navegator
Maybe you should have placed the tape as arrows going to the left, pointing for traffic to move left, maybe the idiots on the cell phones might get the idea that they are about to hit something, we had a disabled fire engine on the side of the road, no lights, no cones waiting for the tow truck, I had to jump down the side of the road, the idiot on cell phone missed the fire engine by inches, this is in broad daylight in sunny California.
navegator
Splashers3
I added 4 additional red reflectors, place right in the middle about driver level.
2017 GMC 3500 Sierra Denali, C/C, D/A, DRW, w/40gal Aux tank, 18K B&W Patriot.
2019 Cedar Creek Hathaway, 34RL2 - w/Bells & Whistles and disc brakes
Traded 2009 Cedar Creek Silverback, GII, 32 WRL
MrWizard
Moderator
Moderator
I use the "red/silver-white" reflective strips
i put them on the back edge of the motorcycle carrier
i but them on the awning arms
i put them on the edge of the steps
and i put them on the folded over edge of my compartment doors
part of this is for my own safety to keep me from banging my head into the things
I can explain it to you.
1997 F53 Bounder 36s
allenm
rockhillmanor
There actually is a DOT formula/regs of how the colors and lines are designed for how far back and how quickly while traveling a driver will see them and how bright they are.
I have a cargo carrier on my toad behind my MH and have been
rear ended into it twice.
When you stop at a light the car behind you approaches for his stop within good distance to not hit it, but then can't see the cargo carrier that is below his line of site, forgets about it and they move up and bang. Or they hit me just coming up to stop.:R
AND when I am parked at a CG or sporting event CG 10's of people have walked right into the side of the cargo carrier at night.
Once I put the red/white reflective tape all around the edge of the carrier all that nonsense stopped. :C
IMHO I would have used DOT approved White on your TT.
You should see how THAT one lights up the sky's at night "way" back "before" you come up on it. Almost blinding! DOT actually rates the reflective tape by candlepower!
We use the DOT approved white tape for just that reason all the time on the back of our horse trailers. To make SURE no one slams into the back of our precious cargo!
BarneyS
Looks to me like he is in the central Florida area.
Barney
2004 Sunnybrook Titan 30FKS TT
Hensley "Arrow" 1400# hitch (Sold)
Not towing now.
Former tow vehicles were 2016 Ram 2500 CTD, 2002 Ford F250, 7.3 PSD, 1997 Ram 2500 5.9 gas engine
