Anybody using a 12v Air Conditioner?
sprintstream
My Class B Motorhome, like many I suspect, gets uncomfortably warm in the back while tooling down the highway during the summer. Passengers and my wife don't like it. I've run my genset and my roof air conditioner to help out but I don't like using up my propane for moving AC. I prefer having full tanks for the genset when needed. I also don't like bouncing around a running AC since I've had problems with stuff shaking, bending and moving.
I've seen many semi trucks with the auxiliary units mounted behind the cab and from what my truck driver son tells me those who have them like them. I've seen some advertised for big boats but I've done a bit of searching and found no one who uses one in their motorhome. Our big 80 amp alternators should easily handle the load through the auxiliary battery system.
Has anyone done this or tried or done more research than me?
Was living the dream in the Ozarks
Now just living
6 REPLIES 6
fitznj
I've had 3 vans (conversion/passenger) with the auxiliary AC units in the
back. Essentially run extra cooling lines to a self-contained cooling radiator and fan. Quite a small unit which does a great jopb of keeping the rear cool.
This is standard equipment on 12/15 seater vans. Call a junk yard and see if they have any laying around.
Gerry
Gerry
sprintstream
I like the idea of the added evaporator in the back using the heavy duty optional engine compressor. Also very pricey but about the same as some of the 12v systems. I believe I'm going to keep my eyes out for a used or salvage kit.
It's interesting that no one has added anything to help this problem. thanks for the input.
Now just living
boogie_4wheel
Vulcan Rider wrote:
The semi trucks don't have 12 V battery systems; 24V minimum and maybe 48.
They are 12V systems. Batteries can be larger, but that depends on the chassis. Our International used 3 car-sized batteries.
Military has (had?) 24V power. The lighting was still 12V (peeled from 1 battery), but had 24V starters, alternators, glow plugs.
2005 2500 Cummins/48RE/3.73, QCLB, 4wd, BigHorn, Edge Juice w/ CTS + Turbo Timer,Transgo Shift Kit ISSPro Oil and LP pressure gauges, GDP 20/2 filters, Custom Diesel Steering Box Brace
'10 Forest River Shockwave Toy Hauler 21'
Honda EU3000I Genny
Big_Katuna
You can add a second alternator. Its an option on F350 trucks.
you can change the 110a alts to twin 140a and have plenty.
There are kits on Ebay. I would not add a 12v AC. Cheaper to buy a 5K watt inverter and run your existing ac off the alternaters.
Entire project under $600.
My Kharma ran over my Dogma.
Vulcan_Rider
I suspect two things here:
It's not practical because.....the entire output of an 80 amp, 12 volt alternator only produces 960 watts; not enough to run a very big A/C unit.
Dr_Quick
Years ago for the "Conversion Vans", they would put in an auxiliary unit to cool the rear of the van. I had a Ford 150 van that I installed a rear unit in it. Ran off same compressor as the in dash air. I mainly consisted of putting "T" fittings in the supply and return lines for the AC and running hoses to the rear of the van. I installed the unit under the rear seat and ran ducts to four locations.
I found one Web Site for you for installing Heat AC to a van. https://www.discountvantruck.com/rvvanrearairconditioners/rvvanconversionrearac.htm
Dr Quick
