Awning repair
CodyClassB
As you see in the photo below, my awning looks bad but it works . Instead of replacing the fabric, can I paint it ? cover it ? We do not use the awning and we just want the RV to look nice when parked in front of our house.
I appreciate your suggestions.
thanks
Moderator edit to re-size picture to forum limit of 640px maximum width.
5 REPLIES 5
Chris_Bryant
Under $100 will get you a new fabric- easy to swap on a window awning.
-- Chris Bryant
Gjac
I bought a can of Latex spray from Big Lots years ago and sprayed the first ft of my main awning where it is exposed. It stopped the leaks where the PO scraped it against a tree limb and made it white again where it was exposed to the elements.
Terryallan
thanks
Take it off. Plug the holes, and don't worry about it any more. No need for it, if you don't use it.
Terry & Shay
Coachman Apex 288BH.
2013 F150 XLT Off Road
5.0, 3.73
Lazy Campers
Peg_Leg
Maybe you could slit a piece of PVC tubing and slip over it for a cover. A quick wipe of the PVC with acetone should clean off any lettering.
2012 Chevy 3500HD Dually 4X4
Crew Cab long bed 6.0 gasser 4.10
2019 Open Range OF337RLS
Yamaha EF3000iSE
retired gadgetman
TucsonJim
The awning fabric is worn out, and you are in danger of it separating while going down the road. If you want a temporary repair, CW and other places sell awning repair tape (often referred to as 100mph tape). You could cover the bad spots with the tape, then spray paint the tape white so it was more cosmetically appealing.
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
